1 - 9 of 9 Posts
My wife's vehicle is a jeep grand Cherokee ecodiesel. It went into limp mode this am with an error message saying DPF is 100% full, service required.
Can I force a regen with Alpha OBD in limp mode or get the ECU out of limp mode then force it to regen ?
Thanks for any help!
first thing to know is .... why did it go to 100%
if it was just neglect and not paying attention to the previous warning the Alfa will work right away .
it could be a bad sensor as Big John had in this thread .
procedure described in the thread , you'll have to read a little , at least not the entire site ...
Filter at 100%, Forced Regen and GDE
he purchased a used crap sensor , and could not do the stationary regen ,
then have a look at
post # 102 , when he got a good sensor the stationary regen worked
Gotcha, thanks, there were no previous warnings about %full, just all the sudden 100% and limp mode. I'll go do some reading
then have a look at
The link provided just goes to a blank page, I tried searching the forum for that title but cant find the thread ...
There is two "force regen" in AlfaOBD:
'DPF Regeneration Enabling' performs a moving regen during next drive cycle,
'Particulate Filter Regeneration' performs a parked regen when coolant is over 140f
I have tried the first one, you actually enable it with the ignition on but the engine not running then turn the ignition back off. Wait a few minutes then start the truck and go for a drive, it will start a regen when warm enough.
Being your getting the 100% full warning, you may need to do the second one, but not sure the exact procedure. You find the regen options in the Diesel Bosch EDC17C49 module
link worked for me ...
here in another form
1 - 9 of 9 Posts
