I have a 14 ram EcoDiesel with 299,600 miles and last month the vehicle stalled and quit as I was driving. Got it to a safe location and checked the codes p0087 and p016F were the codes present. Did some research and found out the HPFP was recalled and the codes pointed me in that direction. Took it to the dealer and they finally got it started and brought it in and said they thought it was the Tone Ring which was also a recall but my VIN did not fall into the recall. They continued to try to tell me that the tone ring was the reason for the codes mentioned above and they would need to replace the tone ring at a cost of $2k to $2500 before they could do the recall on the HPFP which I know the part is not available but I have talked with a Chrysler case manager and she is in agreement to replace all parts as needed with a new defective pump to get me back on the road and when the fix is available they would replace it with the recalled fix.
Would a Tone ring set the codes mentioned above? My thought would be it would set a crank shaft position sensor code not a low fuel pressure code.
Any Help would be greatly appreciated.
