Pre EPA hot tuned ECU for 2016. Engine braking option for 3.55 rear end.
That would make it a GDE "Off Road" tune instead of a "Hot tune"Off road option?
Is this an off-road tune? That would mean if it is you can eliminate all emissions stuff? Thank youPre EPA hot tuned ECU for 2016. Engine braking option for 3.55 rear end.
I'm not sure if there was a difference. It was one of the original tunes GDE did for this motor. I'll try to contact GDE to find out.Is this an off-road tune? That would mean if it is you can eliminate all emissions stuff? Thank you
Yeah GDE made a tune that you disable the EGR valve and they also made it off-road to which you can get rid of the def system. I would be interested if it was a off-road tune which would enable you to eliminate all emissions thank youI'm not sure if there was a difference. It was one of the original tunes GDE did for this motor. I'll try to contact GDE to find out.
I don't think its the off-road but I'll try to find out.Yeah GDE made a tune that you disable the EGR valve and they also made it off-road to which you can get rid of the def system. I would be interested if it was a off-road tune which would enable you to eliminate all emissions thank you
OK thank youI don't think its the off-road but I'll try to find out.
You are correct. Stage 1 it is.Their pre-compliance tunes were Stage 1 with the EGR turned off and Stage 2 for deleting.
If the OP is not deleted he has the Stage 1 tune
They've always been nice and very helpful to me. I absolutely appreciate their tunes and respect the predicament they were put in. Totally different truck with their tunes!Don't waste your time contacting GDE, they will not discuss pre-ban tuning with anyone. They will only discuss current EPA approved tuning.
Great price on your ecm, shouldn't last long.
