Hi all, sad to say I'm joining the one of what looks like many who have experienced engine failures with their EcoDiesel trucks. I purchased mine used (from a Dodge dealership), had 68000km on it at the time of purchase. I've owned the truck for two years and at 129000km I now need a new engine. Not sure exactly how or why, so maybe I could get some insight here. I was driving home when I got an alert on the dash saying oil pressure was low. I checked the oil pressure gauge and it was bottomed out. The engine turned off shortly after. I pulled over, checked under the truck to see if anything was leaking and could not find anything. Couldn't see anything out of the ordinary under the hood, mind you I'm no mechanic and don't know a whole lot about engines and the like. I started the truck back up, the oil pressure gauge returned to normal and there didn't seem to be anything else out of the ordinary. No message on the dash, no check engine light, everything seemed normal. Chalked it up to maybe the electrical glitching out. I put it in drive and after about 200-300m I started hearing a knocking coming from the engine. Pulled over again and checked under the hood again, and the knocking just seemed to get worse. Shut it off and got it towed back to my place. I brought it to a local diesel repair shop where they told me it needed a new engine, and said it was likely related to needing a new EGR valve, which I had an outstanding recall for (I was not made aware of this at the time of purchase) and that it should be covered by Dodge, even being 30k km past warranty. I took it to the nearest Ram dealership and they told me it had nothing to do with EGR valve, and that the connecting rods were blown. I found it odd that they had complete different opinion so I took it to a different dealership and they confirmed what the previous had said.
So here I am, 2 years after purchasing the truck and needing a new engine. I contacted FCA Canada and they basically told me I'm shit out of luck because I'm so far past warranty and there was nothing they could do for me. I guess my question for you all would be what could have lead to this? Truck is mostly highway driven, all oil changes and maintenance was done on time. I was very easy on the truck, have never towed anything and was always very easy on the gas. Dealership tech told me they couldn't tell me why it happened without taking the engine apart and that would just add even more to an already expensive fix - I was quoted $21k CAD, 15k for the engine and 6k for labor. Not very enthusiastic on adding to that. Any insight would be greatly appreciated and if anyone has an avenue to maybe get some help from Dodge on the repairs I would super appreciate that too.
Cheers
Cheers
