Truck has 7k miles on it. This incident has occurred twice. Once a month ago. Once yesterday.
Around 15 seconds after starting the truck and putting the truck into gear (with the knob) the vehicle turns off. There are no engine sounds; it is as if I turned the key off. I coast to the side of the road (with power steering and brakes) and the gear shift knob lights are all lit. I am unable to switch key to the off position(stuck in accessory). Key fob is stuck in ignition. Around 30-45 seconds all accessory power shuts off ( radio, a/c, windows). When I open the door all the lights come on.
The first and second time I was able to temporarily mask the issue by unplugging battery and letting truck reset. After reset I’m not hearing any mechanical or transmission noise out of the ordinary. Although when the truck is turned off under normal conditions I have heard a slight clicking sound (rapid switch like) coming from somewhere near the fuse box. Not sure if that is relevant.
I dropped it off at the dealer yesterday. It’s still under warranty but it’s a problem that I can’t really replicate so I’m unsure of what they’ll say.
after a quick search here I found this thread Engine shut off while driving, would not restart
Symptoms look the same but he was not able to get the truck to turn back on. That truck also had 10x the miles on it and was an older model.
Any ideas?
Any ideas?
