81 - 86 of 86 Posts
Reactions: 97hmcs
So it still stands that most of the emissions are 2y/24k...
No, everything is covered for 3/36 with a new car warranty.
Reactions: NewLove
This is the 2020 verbiage for emissions. Note that they state the DPF is covered.
Rich (BB code):
. Emission Warranties Required By Law
5.1. Federal Emission Warranty
A. Parts Covered For Two Years Or 24,000 Miles Federal law requires
FCA US LLC to warrant the following emissions parts for two years or
24,000 miles, whichever occurs first.
FCA US LLC covers all of these parts under the Basic Limited
Warranty for three years or 36,000 miles, whichever occurs first.
Ram 1500 — Diesel
• Charge Air Cooler (CAC)
• Crankcase ventilation system
• Electronic fuel injection system, including injectors
• Exhaust Gas Recirculation (EGR) valve and control
system
• Exhaust manifold
• Fuel cap, tank assembly, pump, and fuel lines
• Glow plugs
• Intake manifold
• Mass Air Flow (MAF) Sensor
• Nitrous oxide sensors
• On-board diagnostic-system components
• Oxygen sensors
• Particulate matter sensor
• Throttle body
• Transmission Control Module (TCM)
• Turbocharger
• UREA (DEF) tank and control system
• Vacuum hoses, clamps, and fittings, as well as tubing
used for these components
• Vacuum, temperature, altitude, speed, time sensitive valves, sensors,
and switches used in these components
B. Parts Covered For Eight years Or 80,000 Miles
If your vehicle has one of the following parts, this Federal Emission
Warranty covers that part for a period of eight years or 80,000 miles,
whichever occurs first, calculated from the start of the Basic Limited
Warranty as set forth in “section 2.1 E”. The covered parts are:
• Catalytic Converter
• Powertrain Control Module (PCM)
• Oxidation Catalyst/Particulate Filter Assembly
• Selective Catalytic Reduction Catalyst Assembly
5.2. Emission Performance Warranty
The Emission Performance Warranty supplements the federal warranty
under “section 5.1”. It lasts for two years or 24,000 miles on the
odometer, whichever occurs first. If your vehicle has one of the following
parts:  catalytic converter or Powertrain Control Module (PCM), this
Federal Emission Warranty covers that part for a period of eight years or
80,000 miles, whichever occurs first. These limits are counted from the
time when your Basic Limited Warranty begins under “section 2.1 E”. The
Emission Performance Warranty covers the cost of repairing or adjusting
any components or parts that might be needed for your vehicle to pass
Federal Emission Standards for a federally approved state or local
emissions test, but only if:
• Your vehicle has failed a federally approved state or local emissions test.
• Your vehicle has been maintained and operated properly up until it fails
such a test.
• You face a real penalty — for example, a fine or the loss of the use of
your vehicle because the vehicle has failed the test.
81 - 86 of 86 Posts
