1 - 4 of 4 Posts
I just bought 2015 1500 crew with the echo 4x4.
Tomorrow installing 2.5 leveling kit from rough country.
Can i run 35's and if so will i have to do anything else?
Or do i just run 33's
i have the 20 inch rims
thanks
You should be able to run 35's with the 2.5" level. You might have some rubbing on sharp turns though.
My stock 33" Goodyears rubbed when turning to the right. When i got 275/55R20's the rubbing disappeared.
I have a 3 inch leveling kit and run 35x12.50x20s and have no issue with rubbing. The 35's cost me 2 MPG but they look awesome.
I only got the 2" lift and now running 34" KO2's with no rubbing... The ram with the front lift seems to accommodate the larger tires well.
1 - 4 of 4 Posts
