1 - 19 of 19 Posts
What lift do y’all usually run when running 37s? Truck is currently leveled just ordered 37x12 Ssr tires gonna squeeze them on for now since I travel for work and truck sits a lot. Though about 4” but they seem to tower over tires I prefer the mild studded look but still go off-roading when I come home
A guy over on ramforum was running about 1.5" rear 2.75 front and with a bit higher castor up front was running 37 Bfg ko2s with no issue. SSRs will likely be a bit bigger and closer to true 37s, so I'd start with about 1-1.5" rear lift spring and a 2.5-2.75 front and see how they fit. You could always add the zone 1.5 body lift for cheap and get that little bit of extra height as well.
Sent from my SM-N920V using Tapatalk
I appreciate the reply! I honestly don’t know what size level the truck has it came with it it’s not even level front still a shy bit low if they run I think I might go with the 3” coilovers lift
I have a 6" Fabtech lift and 37's and they rub slightly when turning all the way. But it wouldn't take much at all to keep them from rubbing, just don't think about it until I hear it haha.
87077
I have a 6" Fabtech lift and 37's and they rub slightly when turning all the way. But it wouldn't take much at all to keep them from rubbing, just don't think about it until I hear it haha. View attachment 87077
What size wheels I still have stocks. I had 35x12.5 boggers on 20x10 and only rubbed after I messed up inner fender well it pulled it off and tire started catching on drivers side
Discussion Starter · #6 ·
Truck looks killer though I like the grille also are they 37x13.5 or 37x12.5?
20" ballistic wheels. It might be rubbing on the inner fender. I really need to look into it. It only rubs on the driver side so I bet thats it.
The Tires are 37X12.50 R20s
Kinda like a roof leak....Only leaks when it rains, and you can't fix it while it's raining. Then when it clears up, it ain't leaking anymore, so no reason to fix it....
I'm running about 1.5" rear lift and 2.5 ish up front and could fit 37s. I have -6mm offset on my wheels which helps. If they do rub up front it will be on the wheel liners, same with the rear so it's an easy fix. This is all in regards to low speed offroad and flexing, if I get into the high speed stuff I can push my 315/70/17s right into the top of the fenders at full compression. So it all depends what your end use will be. 37s on a 3" (ish) front and 1-1.5" rear lift should fit pretty easily.
Discussion Starter · #11 ·
Ok I appreciate that insight, I mostly go to river pull people out when they get stuck don’t try to hit the mud holes if I don’t have to
Discussion Starter · #12 ·
I learned my lesson when I had boggers framed it out water came in door and broke rear track bar getting snatched out lmao
Discussion Starter · #14 ·
That's great! Yea I say run em! Post some pics too
They came in today, I’m currently in Minnesota for a 10 day shutdown gonna see if my brother can take truck to get them mounted while I’m gone and send me some pics will update soon
87106
Reactions: Gputah
Discussion Starter · #15 ·
87174
Land vehicle Tire Vehicle Car Automotive tire
87175
Welp got them mounted today and only run in reverse have hit curbs while turning already hit a mud hole and it just doesn’t run. 37x12.5r20 with 20x9 stocks 2.5” level in front. Super happy with it
Discussion Starter · #16 ·
How’s that Edodiesel run with those tires, I have the same truck and I’m looking at 37’s also, I do have the Banks programmer already and a 3 front 2 rear lift and 1.5” wheel spacers on stock wheels, been back and forth between 35’s and 37’s
1 - 19 of 19 Posts
