1 - 3 of 3 Posts
Last night I installed the air lift loadlifter 5000 ultimate part# 88370 and the wireless one compressor part# 25870.
Very easy install. Everything fit like it should. Main reason for the install is to have the truck at the proper ride height when towing.
I installed the compressor and manifold behind the back seats. Plenty of room for them. I did this because it made no sense to install a compressor that is not water proof on the frame. I seen this as a possible problem down the road. I also put a T fitting behind the seats and spooled 6 feet of air line so if the compressor fails I can still air up the system if needed.
Initial road test was good. Can not tell much of a difference, if anything it rides a little better.
1 - 3 of 3 Posts
