has anybody ridden in both of the trucks what are your thoughts on the suspension is the Air ride worth the extra money just for ride quality?
Hello Ramvia, Reapur,again i love it only wish the ride height modes would stay at those ride height modes and not adjust back to normal ride height when going over the required speed limit.
In normal, my truck sits as high as my father's '14 hemi 1500 with the coils...Air ride is fantastic. But I wish it was as tall on "normal" as a non-air Ram1500.
does this really work? this is very interesting, is there a video of how to do this step by step?Hello Ramvia, Reapur,
You can change your height to stay in offroad 2 at any speed. All you have to do is put your front links on the back and the back links on the front. This is truly a 5 minute job and only requires a screwdriver. The links pop off with a screwdriver and pop back on with just your fingers. This is how I did it. Put truck in offroad 2 then thru the screen went into suspension setup and selected tire jack mode as this shuts off the air suspension. You can see the link on the front as you kneel beside the tire. Use the screwdriver to pop off the front link, then repeat for the back link and swap them. Now go and do the other side. Got in and started the truck, turned off the tire jack mode, push the down button for suspension and went for a drive. The suspension now has a free two inch lift. You can now go down to entry exit mode but cannot go up to offroad 1 or offroad 2 as your already the same height as offroad 2. Enjoy your 2 inch lift. I would suggest if your going to leave the truck raised 2 inches all the time that you get an alignment as it will help with tire wear.
Mike
Will the truck still self level when i connect my trailer ??Hello Ramvia, Reapur,
Mike
Air ride has a better ride than non. I would give it about 25% better ride over the non.This is interesting. I always just assumed it was simply a height adjustment.
So, the ride is noticeably better than the standard suspension? Is this correct?
There is a whole thread covering air links might read that thread.also when you swapped the links did it level the truck or just raise it all by 2 inches
I drove a non 4x4 ( normal) trucks for 36 yrs. Live in Texas . Don't need itThey make non-4x4 trucks? Why?![]()
Florida.They make non-4x4 trucks? Why?![]()
