1 - 15 of 15 Posts
I’m thinking of converting air suspension back to conventional strut/ shocks and coils. Will standard ram struts fit the front? Strutmasters makes conversion kits, around 1000$. I would then add airbags for helpers on the rear. Anyone else convert?
From what I've read on other forums, they have gone aftermarket with a slight lift to level the vehicle. Sounded like that was a personal preference. The factory control arms must be the same as the mounts for the air suspension sensors are on the conventional suspension arms also.
It appears you can disable the factory air suspension and associated alarms using AlfaOBD
Discussion Starter · #4 ·
Why convert such a nice expensive option?
Front shocks or struts are allowing front tires to hop on rough roads, suspension sags to the left after sitting over night and it sounds awfully exspensive to correct. Tire wear on front is main problem now.
Front shocks or struts are allowing front tires to hop on rough roads, suspension sags to the left after sitting over night and it sounds awfully exspensive to correct. Tire wear on front is main problem now. Handling on rough road on a curve is dangerous
Discussion Starter · #11 ·
Is strutmasters the only place to go? All I’ve found so far! I hate it, love the air suspension but the expense of renewing doesn’t appeal to me.
i removed the air ride on my limited, pretty simple, only took about 4 hours of time. i went with bilstein 5100 front struts and bilstein b12 rear springs. i had a buddy that had a set of factory struts laying around so i was able to use the springs and such for the 5100s. if you do not have access to a set of factory struts you can go with the bilstein 6112 fronts or rough country ones. with alfaobd you can remove the air ride option so you wont get the message and you pull 2 fuses so the compress wont try on. the truck rides so much better with the bilstein struts and springs
86598
I removed the air suspension due to the constant failure in the cold winter in Canada. I do miss having the adjustable ride but the failures always happened when needing to tow snowmobile trailer. Already had compressor replaced once and it seems the mechanics don't have much experience in diagnosing and repairing the suspension without throwing parts at it. Got too expensive.
2015 RAM 1500 Ecodiesel
It’s a 2016 , 147,000 miles
Not bad - your coil overs will also need to be replaced when you reach another 80,000 to 130,000 miles.
Coil overs are a quick and also decent fix for an aging air suspension system.
If you are DIY type you could also go with Arnott springs and keep the ride.
1 - 15 of 15 Posts
