1 - 20 of 23 Posts
Lots of fun was had with Big Blue and the 5 horse today. Got its brakes adjusted and bearings inspected and packed. Then onto the truck.
Oil and fuel filters..... lots of fun in the scorching heat. Far to much for this pasty bastard. 73,103km on the truck and 24,585km on the oil. Only 7,343km worth of towing this time but hauled some decent weight. At least 115,000 pounds of hay in 7 trips.
Out was petrocan duron shp10w30 and the same oil went In. Baldwin bt7349 oil filter was used, which is just a red painted version of the hastings lf608 that was removed.
Lots of cold weather daily driving this index. We had that nasty winter that refused to end. Put 100 idle hours onto this index, which is way up from the average.
Cardan was greased and did a quick drain/fill of the power steering reservoir. Forgot to do the transfer case, so that's tomorrow's job.
I took another used oil sample, which just needs to be mailed out. Although the break in metals should still be higher, I hope to start seeing the downward trend. I full well expect fuel to be up though. Will keep you posted.
Hmmmm! I thought our trucks had an electrical power steering unit. Perhaps I am wrong. It is too late tonight to go out and double check but I don't recall a traditional power steering pump on my truck and wasn't aware of a maintenance requirement for an electric power steering unit. But I could be mistaken.
Perhaps you can enlighten me.
The HD diesels run some sort of hydraboost. Belt driven pump that runs power steering and brake assist. The Ram still asks for ATF+4 in the reservoir.
Thanks. I knew that but missed that it was a HD truck not an ECOD. Apologies to the OP.
Curious about the issue of the bearings and the re-pack.
First I assume you are referring to the front wheel bearings as I can't think of any others that might be serviceable. If so, can those on the 3500's be greased through an ABS port without bearing removal? That is what can be done on the little 1500's but not familiar with the layout on the big trucks.
Discussion Starter · #6 ·
Sorry, I re-read my post and I was a bit vague. The trailer brakes and bearings were dealt with. Absolutely a simple design, so easy to work on.
But.... You can add grease to the HD unit bearings through the ABS port. I have read some posts on a forum or two on that. In fact, I will be doing this next year when I rip the brakes down to grease the slide pins. I will be hitting the 100,000km mark some time, which is a great time to get preventative maintenance done. From what I gather, other than size, bolt count, they are the same damn thing as the 1500 bearings.
Good to read that. Granted they are way more beefy to handle the increased load capacity. Just curious if that was possible by design.
Appreciate the response and other readers may also profit from that knowledge.
Reactions: BrianF
Discussion Starter · #8 ·
Got the used oil analysis back. Nice to see the downward movement in the wear metals. Drop in all, including the "mystery" potassium, which is believed to be from the intercooler. What I did not expect is the 2.5x increase in silicon. I changed the air filter mid index and had it removed numerous times to knock off any debris and inspect it. I suspect that breaking the seal and subsequent inspection caused an intrusion. I do not plan on removal or swapping it out this index. Will monitor.
What I expected and saw, the oil was unaffected. 0.5cSt drop in 100c viscosity, really no shear, no oxidation, little additive depletion. The oil looks good to run much longer. Less than 1% soot and non reportable amount of fuel.
Test 2 and Test 1 are shown together.
Brian,
What do you pay for the set of filters? Looking for a more cost effective alternative to mopar, are the baldwin/fleetgaurds any less expensive?
Till haven't done an oil change on the old mans cummins because he has another 2 free ones, but did the first fuel filter service a while back, not to bad but since there is two of them not as quick as the ecodiesel. The rear water separator filter is just like the filter on our old duramaxes.
When I ordered the parts for his first fuel filter change I bought a set of mopar filters off amazon both fuel filters and an oil filter for $107, not sure if that's good or bad lol.
Discussion Starter · #11 ·
I cannot suggest anything but the OEM fuel filters. I think some guys on cumminsforum are getting fuel filter sets from Athens Dodge off ebay/amazon for under 100$ US shipped as they apparently have a sale on a few times per year. But 107$ US is like 130$ Canadian and that's about the best I can get the fuel filters for, on sale, once a year. In my mind, 107$ is a great price.
Now, if you can piece meal it out, the OEM Mopar rear filter is made by Racor and sold under that, Hastings and the Baldwin names. They usually go for less than Mopar/Fleetguard.
Check Rockauto as well. I know they have the Hastings rear filter, FF1279 on for 36$ US.
I did some research on the oil filter though. The Fleetguard LF16035 is the gold standard. Great filter, great specs and great build but I find the price is bloated. Many 5.9 and 6.7's run their whole life on lesser filtration and survive just fine. I run/ran the Hastings LF608 and now its red cousin, Baldwin BT7349. They are of excellent build and their specs are not far off the 16035 filtration specs. They go for about 12$ Canadian every day (10$ less than the 16035.) I got it for 10$ tax in, on sale. Rock has the LF608 for under 5$ US.
I did a double take on the Dmax fuel filter but it is a different part number than the Ram.
I have been doing some reading about extending my fuel filter changes... after warranty. Ram just uses a basic mileage counter, nothing more, nothing less. In 24,000km I maybe run 2000 litres of fuel (ballpark) through the filters. One guy who hot shots, uses about 4 to 5000 litres in that same mileage. So why cant I run similar volume?
Thanks for the response, I'll keep the part numbers for the other options in mind, but at the moment it seems like the Mopar 3 pack with oil and fuel filers isn't a bad buy and convenient.
I looked at many aftermarket fuel filter options (not baldwin or fleetgaurd), but if I looked hard enough not a single one of them met the micron requirements the Mopar filters are rated for. I wonder how many people use them because they come up on amazon or ebay and just don't know... and how many never have an issue as well.
Thanks again.
Discussion Starter · #13 ·
I know Baldwin/Hastings, Wix all have a front filter listed and I am sure they would provide specs for it but in these parts I found the prices as much or more than OEM.
Anecdotal at best but a friend of mine who runs a 2012 or 2013 F250 PS has run nothing but Wx oil and fuel filters for the last 130,00km on his CP4 pumped engine. He has not run into one related problem.
Probably these filters are just fine but the cost makes them a no go.
Discussion Starter · #14 ·
So in planning for my future maintenance, starting pick up some filters as Cummins is having a somewhat fleetguard sale.
Picked up a ccv and front fuel filter. I have the rear water separator and oil filter on order from amazon. Just need to get the aisin trans filter, 10 litres of atf and 12 litres of engine oil.
What you see here is 162 bucks. The 100,000km maintenance is expensive on a 3500 and a bit more with the aisin. Its steep but my ISB6.7 has expensive taste!
Discussion Starter · #16 ·
Found some oil on sale to try. I had previously been running Petrocan Duron semi synthetic 10w30. I decided to swap it up and go with conventional 10w30.
I chose Federated Co-op DMO into their newer ck4 flavor. It is made locally in their Regina, Saskatchewan refinery. It's similar price to the Duron but not as good cold flow properties. I might add that the DMO cold flow is damn near the same as Rotella T5 semi synthetic 10w30 yet better than Premium Blue semi synthetic 10w30. But less expensive than those both.
85989
85990
Discussion Starter · #17 ·
I rotated the tires yesterday but my master plan was to do preventative maintenance on the brakes. I did a partial brake bleed, it keeps the bleed valves freed up and ensures no air is in the caliper. 11mm wrench is the ticket.
The big ticket item was the slide pins. I like to do them every 2 or 3 years. I have seen what happens when they seize and it's much easier to pop them out once in a while.
No pics but they are super easy on this truck. Easier than my trailblazer, which I did same day. There is ample room and all you need is a small pick to separate the boot or bellow, a 16mm, 13 mm wrench or socket.
16mm up front and 13mm out back. Loosen the caliper bolts and remove one. Pry one side of the caliper to expose the slide pin. Pop it out, clean and regrease. Tap the caliper back in place, replace the bolt and repeat for the other slide.
What I found was nothing exceptional, the thing has 86,000km and is 3 years old. The grease was black but not much for amount. The rear pins were pristine but there was a small amount of corrosion inside the bellows on the front pins.
They were in great shape overall but the sooner you get on this, the easier it gets before corrosion really sets in. I found them easy as there is plenty of room to move and get leverage. Cant remember the name but it's some sort of silicone brake grease I use.
Discussion Starter · #18 ·
I got the oil and fuel filters done today, 25,235km on this index. Used the FS53000 front filter, Baldwin 46031 rear filter and 7349 oil filter. I am now running conventional 10w30.
I decided to try removing the oil filter out the side using the large zip lock bag method. It sucked and I made a mess. Next time I may get that cap tool. I just did not feel like going through the top and removing the intake ducting. Anyway sucks with this truck.
Poor truck was iced up bad but that's life out here. After spilling oil out of the filter I managed to spill diesel from the front filter canister. The damn drain valve may be partially blocked. Got fuel all over the starter and front diff.
Next chance I get i need to chisel out the ice to drop the transmission crossmember to get at the pan. I got 10 litres of maxlife and a filter to deal with.
88159
88160
Discussion Starter · #19 ·
I got the trans service completed and cardan greased. For anyone with the AS69RC, its maintenance is not really fun, less so in winter and outside.
The real issue is the rear most pan bolts. They are very had to access, some state with some flex shafts, wobblies or what ever, they can remove and install them without dropping the crossmember. I had a long hard look at it and decided it would be way too much work for a maybe.
Needed 1/2" for the skid plate, 5/8" for the three nuts on the transmission mount and 24mm socket and wrench for the crossmember.
Support the transfer case with a floor jack and remove three of the four crossmember bolts. Drop the passenger side down, which will need the aid of a pry bar.
All the 10mm bolts are now easy to access on the pan. Drain it and then remove her. The gasket is said to be reusable, which i did. Three 10mm bolts for the filter, which releases another flood of ATF.
Install in reverse. I lubed up the filter O ring and tapped it in place. I partially installed the filter bolts evenly and then snapped the filter into its final place.
Now just the pan holds around 7 litres and I read the pan and filter drop uses less than 10 litres. Well i seem to be wrong.
I added 8 litres, started the truck, which requires a cold reading in park, engine running and fluid at 77C. Now last time I did the pan drain, I got her to cold mark at ambient. This go around I ended up adding all 10 litres. I still ended up with the P0868 low pressure code and it banged in and out of gear. It was still showing low on the dipstick and the code would not clear. After a test drive the fluid was at 60C, still showing low on the dipstick and banging into gear.
Next chance i get i need to pick up another 5 litre jug of Maxlife. So far no leaks though. I did some reading and chose Maxlife LV ATF this go around. Maxlife stated this ATF is compatible with this transmission so I figured it was worth a try. I used an ATP B463 filter as well.
88173
88174
88175
Discussion Starter · #20 ·
Another quick update. I picked up some more ATF to top it off. I went to check it and now showing over full when idling in park and cold.
But the harsh bang when shifting from park to reverse or drive is gone. The range sector works again and it shifted fine on my brief test drive.
Tomorrow I will drain out a couple litres and recheck the level. If I cannot clear the P0868, a few drive cycles should do it.
1 - 20 of 23 Posts
