Ecodiesel brothers and sisters,
I have a question, trying to get a sanity check. Took my 2016 Ram Laramie Ecodiesel in for Electronic Throttle Control Light and the Exhaust System Service required. The 1st time, the dealer diagnosis the problem stating that the throttle is losing connect with the ECM. They disconnected everything and reconnected and everything was working. Picked up my vehicle and drove an hour and a half with a pit stop at a store, and then continued my drive home and 10 minutes after the pitstop, the same lights came back on and of course when these warning lights come on, it reduces power not allowing the engine to rev pass 3,000 rpm and the truck doesn't shift properly meaning I have to take my foot off the gas and it will shift however with the pedal floored, it reaches 3,000 rpms and I could be at 35 mph.
Returned it to the dealer and initial diagnosis was bad turbo. They ordered a new turbo and a week later, they said that I had bad fuel and need new injects and lines and my fuel tank has to be drained and cleaned.
Have any of you had or seen any similar issues? By the way, what's the purpose of the fuel filter if bad fuel made it past the filter into the injectors?
The crazy thing in this explanation is that I've been using the same Shell for the past 6 months or so putting diesel in both my truck and VW however I'm still driving my VW while my truck is in the shop.
Need help!!
Need help!!
