Block heater
1 reading
4.6K views 12 replies 9 participants last post by  DJ-Gregg
#1 ·
Does anyone just leave the block heater plug in all the time
#4 ·
On my other Ram Diesels they were on a timer but I was driving them early AM on a daily basis. Now I may decide to go at 2.00 PM on moments notice so I want it warm. I would only leave it plugged in 24/7 if the weather was forecast to be under 20 degrees.
Reactions: DJ-Gregg
#8 ·
From The Owners Manual:
ENGINE BLOCK HEATER — IF EQUIPPED
The engine block heater warms engine coolant and
permits quicker starts in cold weather. Connect the heater
cord to a ground-fault interrupter protected 110–115 Volt
AC electrical outlet with a grounded, three-wire extension
cord.
Its use is recommended for environments that routinely
fall below -10°F (-23°C). It should be used when the
vehicle has not been running for long periods of time and
should be plugged in two hours prior to start. Its use is
required for cold starts with temperatures under -20°F
(-28°C).
To ensure reliable starting at these temperatures, use of
an externally powered electric engine block heater (available
from your authorized dealer) is recommended.
66 STARTING AND OPERATING
#9 ·
RB-Seems to me it still makes sense to have a timer. IF you are truly leaving it plugged in all the time you can have it shut off when you are sure you are not going to take the truck out. FOr example 11PM - 5AM or whatever would give you a warm truck from about 7AM-midnight and save something like $10 per month on your electric bill.
All the best
#10 ·
Only plugged mine in a few times last year. It is a pretty good cold weather starter. i usually walk the dog before going to work in the morning, and on really cold mornings I will typically start the truck before taking " mon chumm" on his morning constitutional.
#13 ·
They are installed in place of a brass frost plug in the side of the block. Usually if they fail, drain the coolant pull the old one out and press a new one in.
They don't fail as often as you'd think. The one on my '94 Chev 6.5L still worked when I got rid of it 6 or so years ago. When it does happen though, some people just cut the lower rad hose or a heater hose and put an aftermarket in-line heater in its place.
