Does anyone here actually use it vs normal def?
I don't. I buy the cheapest as DEF is DEF.Does anyone here actually use it vs normal def?
Is it? I saw that BlueDEF Platinum specifically says it contains a "proprietary additive package". Are they just bald-faced lying about that?I don't. I buy the cheapest as DEF is DEF.
I'm just referring to the DEF ingredient. They can add all the additives they want, there's 33.5-33% DEF in it. DEF is DEF.Is it? I saw that BlueDEF Platinum specifically says it contains a "proprietary additive package". Are they just bald-faced lying about that?
This: https://asset.productmarketingcloud.com/api/assetstorage/2482_96eedd36-4670-4e1e-bb2e-30e40ce33059
says this: "BlueDEF PLATINUM™ with advanced SYSTEM SHIELD™ technology is a mixture of high purity synthetic urea, deionized water, and our proprietary additive package manufactured under ISO 22241 guidelines to ensure product quality"
and is from here: https://www.owi.com/commercial/bran...t-fluid/bluedef-platinum-diesel-exhaust-fluid
Click the link to download Specs to get to the PDF.
But then, what you posted sounded like an answer to the OP's question, but it really wasn't, was it?I'm just referring to the DEF ingredient. They can add all the additives they want, there's 33.5-33% DEF in it. DEF is DEF.
True. But, whether it is better or not, it is not accurate to say that it is the SAME as the other DEF that doesn't have that unobtainium in it.Well I suppose you can add 3 crystals of unobtainium or nonreactium and then claim it's got a proprietary product that makes it "better" I put Helium in my tires, it lowers my GVW by 10%. Just pulling legs.
DEF is not 100% DEF? Is water not 100% water? Is gasoline not 100% gasoline? You said earlier that DEF is 33% DEF. That is not correct.I mean exactly what I said, DEF is DEF. DEF is not 100% DEF!
Any package or pump identified as DEF, by EPA's rules, has to contain a volume of no less than 33.2% Urea and 67.5% demineralized water.
As far as I know, Peak's (Old World Industries) Blue DEF Platinum has 33.2% of synthetic urea plus their proprietary additive.
If you have any data to the contrary, please post it
I posted links above to the documents stating what is in a jug of BlueDEF Platinum.If you have any data to the contrary, please post it
Yeah, you are correct. It's not grammatically correct to say DEF is 33%. By definition, DEF is 100%.DEF is not 100% DEF? Is water not 100% water? Is gasoline not 100% gasoline? You said earlier that DEF is 33% DEF. That is not correct.
So, is the liquid in a jug of BlueDEF Platinum DEF or not?
So, is a jug of BlueDEF Platinum DEF or not?Yeah, you are correct. It's not grammatically correct to say DEF is 33%. By definition, DEF is 100%.
The point was DEF only has 33.2% Urea and DEF is DEF.
Yes, Blue DEF Platinum is DEF, with an additiveSo, is a jug of BlueDEF Platinum DEF or not?
The OP was asking about using BlueDEF premium (which I took as really meaning Platinum). So, are you saying that is not DEF? Or are you saying it's exactly the same as, for example, SuperTech DEF?
Interesting, Old World Industries LLC announced the launch of BlueDEF PLATINUM on November 25, 2020, just over a year and a half ago.I've been running Platinum DEF for about 3.5 years.
I remember buying a few boxes but not using it until the old DEF was mostly used up. According to my records, I added 5 gallons of Platinum DEF in 11/29/2020. That was when I switched over. So, based on that information, I've been using it for a little over 1.5 years. It seems like it's been around for much longer than that, but my records show otherwise.Interesting, Old World Industries LLC announced the launch of BlueDEF PLATINUM on November 25, 2020, just over a year and a half ago.
