I have a 2018 RAM Laramie EcoDiesel and just put 7500 miles on the truck pulling a 7K lb trailer. Coming from Kansas City, MO to Mesa, AZ I encountered a far number of uphill grades. The truck cut out abruptly a few times climbing those grades. I believe because of high temperatures for coolant, oil, and transmission as noted by many discussions. I just monitored the coolant gauge on the dash which went to the 3/4 mark or mark prior to red so I don't know exact temperatures. The outside temperature was between 95-102 degrees.
I'm thinking about going to aftermarket honeycomb grille similar to the one Nitis installed on the white ram 1500. How big was the impact of that aftermarket honeycomb grille vs stock grille? Why was honeycomb chosen over mesh or slotted aftermarket grilles? We have lots of cracked windshields in AZ from debris on our highways, how did your aftermarket grille do in protecting the three stacked coolers from rocks and insects?
