21 - 40 of 58 Posts
· Registered
I'm really hoping this will be your tone wheel. Just as a FYI, check your starter ground wire. My dealer had to replace mine. I think the wire might get hot because of the longer starts with the failed tone wheel.
Reactions: jhauler55
· Registered
Discussion Starter · #24 · (Edited)
You and I both! I figure, either its the tone wheel or its not! 🤣
I can spend more time with the scope trying to interpret CKP sensor waveforms until the moon comes up and I feel I will always have the same result. Inconsistencies. Which could be a depiction of many variables. The biggest one being myself. However, the truck still does not run until a wrench touches metal. Time is of the essence and time is spread thin these days.
Now, I dont want to bark too much before I get myself bit by Murphey, but the job is literally just loosening a handful of nuts and bolts and moving components out of the way. There isn't much too the job as long as whoever the "monkey" changing the parts is, has access to a few (not many) basic hand tools, and preferably a shelter to do it in. Which I am blessed to have both.
The hard part is troubleshooting a vehicle that has limited resources available. Takes more than a monkey with a wrench. Thats where you all come into play ofcourse! 🤣 I am here for the vast amounts of knowledge and plan to pay my dues thru contribution.
This isn't nearly as bad as drilling busted header studs out of a Ford 300. Or even replacing the engine oil in a Tesla. Certainly, in my opinion anyways, does not warrant tossing 3k in labor fee's to a dealership full of "We'll get to it next week. Possibly." OEM mechanics.
· Registered
Discussion Starter · #25 ·
Assuming you will also replace the crank positio0n sensor. I suggest using an OEM sensor.
Mopar seems to of dropped the price from what it was rumored to be on the CKP sensor. I have heard 650 bucks. I have heard 300 bucks. But it looks like they have the wheel for $25 and the sensor for $130 or so.
People have issues with non OEM sensors?
· Premium Member
Run. Get that GDE ECM.
You get the tone wheel sorted out then do not miss that GDE programming. It would eliminate your EGR issues by shutting it off.
· Registered
Discussion Starter · #29 ·
No kidding! After this reluctor wheel is fixed, the intake is coming off. Really would rather not have to replace it again in 75k miles. Sure seems like it shouldn't be a "wearable part". Thanks EPA!
· Registered
Discussion Starter · #33 ·
There is more up top middle area
You stand corrected. Thanks! 10 bolts total. The upper 2 are hard to see and one of them you will need a 3 to 4ft extension over the top of the gearbox in order to break lose.
Saying that, and 403583 electrical connections later, I have the gearbox separated.
Hood Motor vehicle Electrical wiring Auto part Wire
A worry of mine however, is I lost about a pint or so of trans fluid out of the bell housing when I separated the trans from the engine block. Could this be fluid that leaked out of the input shaft area of the torque converter due to the angle I was at or was this fluid from something more sinister such as a broken seal in the pump or torque converter?
I will have to inspect everything carefully when I get it pulled away more. Ran out of time and had to head to work.
Thanks guys!
· Premium Member
2016 Big Horn 4X4 Engine and Transmission tuned by no longer available (but truck runs good)
Thanks guys!
betting a "pint" it is just some that leaked out of the torque converter, thinking you would have seen a leaking seal before the work you're doing even started
· Registered
Truck: 2015 Tradesmen, 4x4, 133k miles on the O. AEM stock tune, no W58 completed as of yet. (wish i did)
Problem: Cranks, no start
Symptoms: Truck started, drove 50 feet and than stalled with the ole TPS fault on the dash HMI. No start after.
Completed items: Battery is on charger when I troubleshoot. Fuel Filter changed when problem ocured. Always on time with PM schedule. Shell Rot. 5/40 used. Mobile 5w40 was used during the Rotella shortage of 2021. NO codes for anything relating to no start. I have my typical dirty intake swirl valve codes, along with a p0128 code that I cannot fix even tho T-stat is new. 5 gallons of new fuel added to tank.
Had my ED towed to my house a day ago since it would crank but no start. It sounds like its about to take off and fire, but never does. So its not just a crank, no start. Its a crank, almost start, no start.
I will post the AlphaOBD report, but keep in mind this was preformed with a non running engine that was only cranking. I noticed on one report, it claimed I had water in the fuel. This is why I added new fuel. Reports after claim no water. Never had any kind of light and the ECM (in alphaOBD) claims the truck has driven 0km lifetime with a water warning. So, not sure why thats there. I also noticed an alternator fault on the report. Never had any voltage or charging issues so not sure what to think here. Crank signal according to AlphaOBD is not dropping and is recognized. Fuel rail says its getting pressure on A-OBD and the lift pump turns on (going by ear) for 30 seconds, primes, and shuts off.
My gut tells me its the reluctor magnet. My heart wants it to be the alternator. Could the alternator issue of been masked by a battery that was strong enough to run all the glow plugs/injectors/pumps. I am fully prepared to drop this transmission and change the part in my cold wet driveway if thats what it will take. But I dont have the time or money to be a part changing monkey. I need a surgical diagnosis before my mitts get dirty. Single father with 3 children, full custody, and this is our only vehicle. Its my bread and butter and I need it NOW!
In the meantime, Im dropping 400 dollars a week on a rental car and skipping important bills along the way. My only option really...
I have a video of the truck cranking and sputtering, and I can provide any A-OBD reports needed. Attached is a report I pulled while I was cranking away hoping for a miracle.
My next step, i guess, is to remove the starter and use a bore scope to maybe try and see the tone ring. At least that will give me a solid path forward.
Any help is appreciated.
PS: The "alternator" fault... Is it faulted because its not being run/excited?
Vehicle Line: DS - RAM 1500
Model Year: 2015
Body Style: 4-Door Pickup
Country Code: USA
Assembly Plant Data:
Normalised (Absolute) accelerator pedal position 1 for OBD tester: 0.00 %
Normalised (Absolute) accelerator pedal position 2 for OBD tester: 0.00 %
Engine speed: 0.00 rpm
Boost Pressure: 963.00 hPa
Raw value of Terminal 50 from hardware: Off
AC Fan Request: Off
Air conditioner compressor request: On
Raw signal from the digital gearbox neutral position sensor: On
Clutch switch: Off
Clutch Interlock Switch: Off
Redundant Brake Switch Status: On
Main Brake Status: On
Air mass per cylinder: 0.00 mg/hub
Vehicle speed: 2.56 km/h
Cruise control status: Not defined
4WD Switch state: Low Range
Cruise control: Standard Cruise Control
5 Button Cruise Control: No
Select Speed Control: No
Active Grille Shutter Equipped: No
Electric Thermostat Heater Equipped: No
Vacuum Pump: Yes
Air Condition: Fixed Displacement
Active Noise Cancellation: No
EGR bypass position sensor: No
Electric Coolant Valve Equipped: Yes
Stop&Start: No
DEF (urea) system: Yes
A580 Variant Equipped: No
PWM Fan: Yes
Low/High Fans: No
ABS: ABS with ESP
4 pin MAF: No
8 pin MAF: Yes
Swirl Position Sensors: Yes
Oil Vapour Pressure Sensor: Yes
EGR Out Temp Sensor: Yes
CAC In Temp Sensor: Yes
Status of Transmission type: Automatic
Lambda/Particulate filter presence: Not defined
PTC Equipped: 3 PTC heater relays, 3 heaters
Gear Shift Indicator: No
ADJ Starting Torque: 0.00 Nm
ADJ Idle Speed: 0.00 rpm
ADJ Tire circumference: 4123.20 m
MIL: Off
Engine condition status:
Regeneration Status: No
Boost control status: Disabled
EGR Control Status: Disabled
EGR cooler bypass status: Off
LSU signal is valid: Yes
Glow plugs activated: No
Water In Fuel: Not present
Main Brake Status: Pressed
Redundant Brake Switch Status: Pressed
Clutch pedal: Pressed
Fan powerstage 1st command: Not activated
Fan powerstage 2nd command: Not activated
AC requested: Not requested
AC compressor switched ON: Yes
Status of injection:
Main injection: Not present
Pilot injection 1: Not present
Pilot injection 2: Not present
Pilot injection 3: Not present
POST 1 injection status: Not active
POST 2 injection status: Not active
POST 3 injection status: Not active
POST 4 injection status: Not active
Starter Relay Status: Off
Air Condition Compressor Off: On
Crankcase Ventilation Heating: Off
Glow plugs lamp: Off
Glow plugs relay: Off
Pre-Supply Pump: Off
Fuel filter heater: Off
Fuel filter water level warning lamp: Off
Raw digital inputs & outputs:
Key status: On
Redundant Brake Status: Pressed
Request To Switch On/Off The Main Relay: On
Control Signal for the Starter Relay: Off
Converted Analog inputs:
The Pressure at Turbine Upstream: 967.00 hPa
Sensed Value Of The Temperature At Particulate Filter Upstream: 10.06 Deg.C
Air temperature at HFM position: 14.56 Deg.C
Sensed value of environment air pressure: 970.00 hPa
Sensed battery voltage: 12440.00 mV
Sensed fuel temperature: 6.66 Deg.C
Charged Air Cooler downstream Pressure: 963.00 hPa
Sensed inlet air temperature: 5.96 Deg.C
Lambda value measured from LSU: 0.00
Air mass per cylinder: 0.00 mg/Hub
Engine oil temperature: 4.26 Deg.C
Sensed pressure downstream of the particle filter: -2.00 hPa
Maximum rail pressure during last 10 ms: 7.10 bar
Engine coolant temperature: 5.06 Deg.C
Sensed value of the temperature at Ttrbnus: 11.36 Deg.C
Temperature before OxiCat: 10.06 Deg.C
Sensed value of oil pressure: 25.00 hPa
Sensed value of actuator position without error handling: 4.99 %
Cruise control status: No Key Pressed
Accelerator pedal: potentiometer track 1: 0.00 %
Accelerator pedal: potentiometer track 2: 0.00 %
Crankcase differential pressure sensor signal: 0.03 hPa
Conditioner pressure: 3628.00 hPa
3 way Coolant valve actuator position sensor signal: 0.00 %
Temperature before Oxidation Catalyst: 8.66 Deg.C
Temperature before Particulate Filter: 9.86 Deg.C
Temperature before Turbine: 10.46 Deg.C
EGR rate into the engine: 0.00
EGR cooler downstream temperature: 5.36 Deg.C
Radiator out temperature sensor signal: -50.04 Deg.C
Charged air cooler Upstream temperature: 4.66 Deg.C
Nox concentration of Nox Sensor 1: -7.00 ppm
Nox concentration of Nox Sensor 2: -4.00 ppm
NOx emission downstream of secondary catalyst: 0.00 ppm
Offset corrected NOx signal from post NOx sensor: 0.00 ppm
Swirl valve actuator sensor position 1: 0.08 %
Swirl valve actuator sensor position 2: 36.16 %
Pressure downstream of air filter: 962.00 hPa
Relative humidity of fresh air: 51.18 %
Turbocharger position control: 84.08 %
SCR Urea Tank Temperature: 3.86 Deg.C
SCR Urea Level: 52.28 %
SCR Urea Level: 95.00 mm
Urea (Reductant) Pump Pressure: 0.00 hPa
Exhaust gas temperature Upstream SCR: 5.46 Deg.C
Raw analog inputs:
Raw Voltage Value of Particulate Filter Upstream Sensor: 811.20 mV
Raw ADC value of environment air pressure: 3831.60 mV
Raw ADC signal from environment temperature sensor: 0.00 mV
Raw ADC value of fuel temperature: 3910.00 mV
Raw value of voltage read from ADC for charged air cooler downstream pressure module: 1558.80 mV
Raw ADC value of downstream charged air temperature: 4388.20 mV
Raw voltage value lambda signal after subtraction of reference 1.5 Volt: -9.60 mV
Raw ADC value of oil temperature sensor: 4325.40 mV
Raw voltage from the ADC PFlt Differential Pressure sensor: 566.80 mV
Raw value of temperature at upstream of the oxidation catalyst: 806.40 mV
Raw voltage value of position sensor: 889.40 mV
Raw value of rail pressure: 513.00 mV
Raw ADC value of downstream engine coolant temperature sensor signal: 3416.20 mV
Turbine Upstream Temperature Sensor Voltage: 811.20 mV
Accelerator pedal: potentiometer track 1: 425.00 mV
Accelerator pedal: potentiometer track 2: 214.80 mV
Crankcase differential pressure sensor signal: 850.20 mV
Conditioner pressure: 522.80 mV
Temperature before Oxidation Catalyst: 806.40 mV
Temperature before Particulate Filter: 811.20 mV
Temperature before Turbine: 811.20 mV
EGR cooler downstream temperature: 796.60 mV
Radiator out temperature sensor signal: 4999.80 mV
Charged air cooler Upstream pressure: 4629.80 mV
Swirl valve actuator sensor position 1: 503.20 mV
Swirl valve actuator sensor position 2: 1871.60 mV
Pressure downstream of air filter: 3768.20 mV
Urea (Reductant) Pump Pressure: 0.00 mV
Exhaust gas temperature Upstream SCR: 801.40 mV
3 way Coolant valve actuator position sensor signal: 2805.20 mV
Status message for vehicle pedals:
Clutch pedal pressed: No
Accelerator pedal potentiometer 1 used: Yes
Accelerator pedal potentiometer 2 used: Yes
Accelerator pedal error condition: No
Brake Pressed: Yes
Redundant switch brake pedal pressed: Yes
Brake switch error condition: No
Throttle status:
Throttle open: No
Throttle in required position: Yes
Throttle valve in fault: No
Status message for pre-supply pump:
Pre supply pump Command On: No
Engine Crank: No
Fuel pump relay in fault: No
EGR: On
EGR in fault: No
Air flow sensor in fault: No
Status message for oil pressure switch:
Oil pressure switch: Off
Engine Running: No
Insufficient oil pressure with engine running: No
oil sensor in fault: No
Oil pressure lamp status: On
Boost closed loop controller is active: No
Position controller enabled: No
Offset learning procedure already performed in this driving cycle: Yes
Gear engaged: 0
Enable Fuel Pump to Energize: On
LIN Values:
Alternator Load: 0.00 %
Alternator Load Response Ramping Time: 5.75 sec
Alternator Voltage Set Value: 0.00 mV
Engine speed: 768.00 rpm
Alternator Excitement Current: 0.00 mA
Alternator Status High Temp Fault: No
Alternator Status Mechanical Fault: Yes
Alternator Status Electrical Fault: Yes
Alternator Status Communication Fault: No
Alternator Status Timeout Fault: No
LIN output error state: No
Any Alternator Error Present: Yes
Alternator Parameters:
Current state of the LRT calculation-- engine speed is greater than threshold: No
Battery temperature: 10.06 Deg.C
Alternator Set point Voltage: 0.00 mV
Alternator load response time: 5.75 sec
Battery Voltage after Defect Detection and Handling: 12440.00 mV
Alternator Excitation Current: 0.00 mA
Km with 'Water in diesel' warning lamp 'ON': 0 km
Cruise control status: :
Cruise Control Speed: 0.00 km/h
Cruise Switch 1 State: No Key Pressed
Cruise Switch 2 State: No Key Pressed
Engage & Enable not Inhibited: No
Cruise Control is Off: Yes
Wheel Spin Detected: No
BRAKE SWITCH PRESSED: Yes
P/N SWITCH in P or N: Yes
Inhibit Software Declutch Detected: No
CLUTCH UP STOP SWITCH PRESSED: Yes
Vehicle speed Greater than High Limit: No
Vehicle speed Lower than Low Limit: Yes
Engine RPM Greater than High Limit: Yes
Vehicle Speed Less Than CC Minimum Set Speed: Yes
Clutch Interlock Switch Pressed: Yes
TPS Limpin: No
MAP Sensor Limpin: No
Crank Signal Intermittent: No
No Trans Bus Message: No
Trans Flt Current (OBD2): No
Cruise Switch Failed: No
Pedal Sensor Failure: No
Level1 Safety Cruise off Request: Yes
Level1 Safety Cruise Disable Request: No
Cam Signal Missing: No
Cam/Crank Signal Tolerance: No
Crank Signal Missing: No
Cruise Not Learned/Configured: No
4WD Low: No
Disengaged Due To Disenabled: No
CANCEL SWITCH PRESSED: No
BRAKE SWITCH PRESSED: No
P/N SWITCH in P or N: No
CLUTCH UP STOP SWITCH PRESSED: No
N/V > High Limit: No
N/V < Low Limit: No
Engine RPM Greater than High Limit: No
Set Attempted Below Intelligent Cruise Control (ICC) SET MPH MIN: No
Clutch Interlock Switch Pressed: No
Cruise Disabled: No
On/Off switch Pressed: No
TPS Limpin: No
Level1 Safety Cruise off Request: No
4WD Low: No
Auxiliary Heater Information:
Coolant Temp Limitation: 156.00 Deg.C
Actual Coolant Temp: 4.80 Deg.C
Actual Ambient Temp: 4.00 Deg.C
PTC enable automatic control status: Not requested
PTC 1 Relay Request (Bus Message Tx): Not requested
PTC 2 Relay Request (Bus Message Tx): Not requested
PTC 3 Relay Request (Bus Message Tx): Not requested
Add-on heater status (PTC relay #1 status) via CAN: Not requested
Add-on heater status (PTC relay #2 status) via CAN: Not requested
Add-on heater status (PTC relay #3 status) via CAN: Not requested
RPM Threshold Not Achieved: Yes
Fuse condition for stepwise switch-off: No
Ignition Off-Draw (IOD) Fuse Pulled: No
Battery Voltage Too Low: No
Alternator load too high: No
HVAC Rear Defeat Message: No
HVAC Front Defeat Message: Yes
Coolant Temp Too High: No
Start Delay not achieved: Yes
PTC Heater 1: Off
PTC Heater 2: Off
PTC Heater 3: Off
Fixed Displacement A/C Status:
A/C Coolant Pressure: 3600.00 hPa
A/C Pressure Upper Limit: 32800.00 hPa
AC Disabled Due To Coolant Temperature Too High: No
Defrost Selected: No
A/C Selected: No
AC requested: Yes
Status of A/C Switch: Off
Fan Request 1: Off
Fan Request 2: Off
Variable Displacement A/C Status:
A/C compressor PWM status: 0.00 %
Evaporator temperature: -4.80 Deg.C
Evaporator Target Temperature: 29.60 Deg.C
Ambient temperature: 4.00 Deg.C
AC Evaporator Temperature Failed: No
A/C Head Pressure Cut Out: No
AC Evaporator Temp Message Cut Out: No
AC freeze flag: No
A/C Compressor Over speed Cut Out: No
A/C Selected: No
AC requested: Yes
Fan Request 1: Off
Fan Request 2: Off
IMA/IVA code of injector cylinder 1 (6 Cylinder Application): 7RGK255
IMA/IVA code of injector cylinder 2 (6 Cylinder Application): 81R64A6
IMA/IVA code of injector cylinder 3 (6 Cylinder Application): ASZEA1A
IMA/IVA code of injector cylinder 4 (6 Cylinder Application): 8IHH6WA
IMA/IVA code of injector cylinder 5 (6 Cylinder Application): 78ZRYW4
IMA/IVA code of injector cylinder 6 (6 Cylinder Application): 6Y6ZZ13
Hey there,
If you're still needing any assistance with this, we'd love to see what we can do to help. We're available via direct messaging.
Callie
Ram Cares
· Registered
I spy with my little eye.
That is an incredible amount of work for a 25 dollar doodad.
I'm just happy you found your problem! And you should be, too! That's about the cheapest repair you can have. Labor intesive, but cheap! (y)
· Registered
Discussion Starter · #40 ·
Oh it tastes very sweet. I had been preparing myself for the occasion of not seeing a damaged ring upon flex plate removal after all that wrenching and maneuvering. Telling myself that this has to be done anyways.
Happy is an understatement ! !
21 - 40 of 58 Posts
