And this also confirms that if your reluctor fails similar to the way mine did with only 2.5 segments missing, your vehicle may not throw a DTC and may sound like its going to start if you just keep cranking. This was information I could not find anywhere. Now we know.
When mine failed I was not doing anything other than pulling out of my works parking lot to head home. Idle speed with no prerequisites prior to detonation.
If anyone does this with a floor jack, make yourself a wooden carriage for the trans to ride on with center of gravity kept in mind. The transfer case is left on the trans to make the job easier. This however makes the entire gearbox very back heavy. I used a ratchet strap to counter this balance issue, however I would recommend picking your load points in a better thought out position. I had a few very close calls and if that baby ratchet strap decided to snap, the night could of had a much different outcome. Not worth it. Be smarter.
Could it of been too hard to just make this a sprocket like many other vehicles? And maybe even get crazy and engineer it on the front of the block? FFS...
Up next, a GDE PCM and a new intake manifold/plenum.
