I need to buy that line, too. I assume you used the Dorman part# 667-562?The upgraded part utilizes a stainless braided hose which will stand up to the environment its in much better.
Here you go sir!!I need to buy that line, too. I assume you used the Dorman part# 667-562?
I already had it in my cart!Here you go sir!!
Dorman 667-562 Turbocharger Water Feed Line Compatible with Select Jeep/Ram Models (OE FIX)
Buy Dorman 667-562 Turbocharger Water Feed Line Compatible with Select Jeep/Ram Models (OE FIX) at Amazon. Customer reviews and photos may be available to help you make the right purchase decision!www.amazon.com
What I can tell you is that the 10 year/150,000 mile coolant showed that it needed to be changed when I pulled a coolant sample at 94,993 miles. Since the system is very difficult to flush, I now drain and fill every year via the radiator drain port. The entire coolant system is only 11.6 quarts. When I do a drain and fill, I get about 3 quarts (approximately 25% of the system) to drain. This is with the truck parked on ramps. So, whatever you do, just remember, coolant is cheap and easy to replace. I haven't had any problems with trapped air pockets in the system by this simple and drain procedure.On a side note, does anyone know the procedure for the turbo coolant line replacement? Drain all coolant from engine? Drain a little? Drain none? Also, ive heard rumblings about the turbo needing to come out. Is this true? I think if I unbolt the banjo fitting on the turbo for the upper coolant hose, I should be able to get to the banjo fitting bolt on the one I need to change.
I was hoping that to be the case. I have the battery on the charger currently. I couldn't understand why the crank sounded slow. Battery was on the charger while cranking so I know its not the battery. I cross referenced my alpha OBD analog sensor log from before and after the rebuild just because there were so many sensors I had removed/unterminated. The only thing I see that's different (besides my swirl valve percentages being where they should be now) is a "Alternator Load Too High" signal. This is not an OBD code, just a parameter in the PCM. I can say, it definitely sounds like its overloaded. I didn't have much time to dig deep.No need to purge the high pressure fuel system just cycle the key a few times to purge the low pressure and it should self prime in 30-60 seconds of cranking. Make sure and charge the battery as well so it cranks faster.
I run Amsoil in mine. Amsoil makes the OTL and ATL fluids. If you're a preferred customer, it comes out to $9.39 per quart for the OTL and $16.29 per quart for the ATL. I'm planning to do a drain and fill every 50,000 miles on my trucks. Note: I have the PPE transmission pan.Going to have to hit up the dealership for a quart or 2 of thier not 40 but 60 dollar 8/9 speed fluid. Crazy times we live in. 🤣
152k miles My tone wheel went out on my test drive lol. lost all power pulled onto a side street (2 blocks from home) called dealership to come get there S%&* flatbed there in 35 min. 2 weeks later tone wheel and a couple other things found while tore apart were fixed. been a great truck last year and a half went down a month ago for a valve body covered by extended warranty! So all said and done 300 out of pocket i cant complain about it.....My truck had 133k miles when the tonering flaked out. I did not have the software patch/recall done but I did have AAA. Which was nice.
I have used Amsoil a few times. Certainly a great product. Gale Banks did a video on his youtube channel where he toured the Amsoil facility in Wisconsin, USA. That particular video really made me actually understand the real world engineering problems of manufactoring bulk, multiple blends of oil. The amount of things that can go wrong in the process is incredible. The amount of effort and money investments Amsoil has done to thier quality control of end product is amazing. When you actually dive into the history and the facts of Amsoil, you start to understand why it's so highly reguarded as the best of the best. I would switch to Amsoil in a heartbeat, however on a 8HP with 135k miles under its belt, I'm hesitant to say the least. I would like another 150k miles out of this gearbox lord willing. So far, the Mopar 8/9 fluid has proven to me that it can handle 150k. Why switch now? Not to forget the amount of work it would be to completely 100% drain the gearbox, TC, Cooler and lines, ect. In order to avoid cross contamination of the 2 fluids.I run Amsoil in mine. Amsoil makes the OTL and ATL fluids. If you're a preferred customer, it comes out to $9.39 per quart for the OTL and $16.29 per quart for the ATL. I'm planning to do a drain and fill every 50,000 miles on my trucks. Note: I have the PPE transmission pan.
Sorry to hear this my friend. Its a real bummer. It really tested my wits at a terrible time in life. Im writing a paper currently about our ED powerplant specifically, that will delv into the science behind the reluctor wheel style that is used on these trucks. As well as, why it is where it is. There are actually benefits to having a rear mounted CKP. A lot of them are related to crank harmonics. But the style of tone ring they currently use has some engineering yield points that are easily met by our trucks. Sometimes they fail in trucks with years of use left. The amount of money we are willingly paying for these vehicles is insane. But thats really just the tip of the iceburg... Dont need to go there..152k miles My tone wheel went out on my test drive lol. lost all power pulled onto a side street (2 blocks from home) called dealership to come get there S%&* flatbed there in 35 min. 2 weeks later tone wheel and a couple other things found while tore apart were fixed. been a great truck last year and a half went down a month ago for a valve body covered by extended warranty! So all said and done 300 out of pocket i cant complain about it.....
