1 - 4 of 4 Posts
Greetings all,
I have a Canadian build 2014 Laramie Limited and my daylight running lights are no longer functioning. Could not find a specific fuse related to the DRL. So, after searching around the internet there was a post mentioning the DRL module could have failed. Do we have such a module on our trucks and if so where is it located so I can investigate further and order a replacement? I do remember replacing a DRL module on my 2000 Dodge Dakota many years ago.
Thanks,
Jerry
Jerry,
The DRL's are controlled via the BCM. (Body Control Module). no fuse or dedicated DRL module.
I have no idea why they would have dropped out but a quick look with AlfaOBD would most likely give you a clue.
sky
Well I noticed the DRL are working again, but sometimes the headlights are full on and its not dark out. Wipers are off as well as I know they can control the lights. Very strange.
Jerry
1 - 4 of 4 Posts
