1 - 20 of 23 Posts
I’m curious if anyone knows what the dealer mechanics actually do/look for when I go in for a regularly scheduled oil/filter change.
I find the prospect of maintaining a diesel on my own a bit more overwhelming when compared to a gasser, so I’m curious if there is anything specific I should look for or do for regular maintenance (lube points, inspections, etc).
I just got my GDE tune (love it) and I’ve done the rear axle and transfer case oil changes. Oil changes cost nearly $300 in the east GTA (probably similar across Canada).
What do you folks do for regular maintenance?
I took my 2015 Ecodiesel in to the dealership for all service as the dealership offered half price oil changes. When I traded the 2015 in on my 2017 Ecodiesel they no longer offered the half price oil change so I called FCA to see if they had a reduced oil change coupon. FCA added two FREE oil changes to my account just for calling and asking. I was very thankful to FCA for this gift. For my third oil change....I could only find FCA coupons for oil changes on gassers so I called them again. They sold me 4 oil changes for $400 US, so I continue to go to the dealership.
Work they do:
Change oil and filter
Rotate tires and show me tread depth
Adjust tire air pressure
Measure brake pads and show me life left
Check and top off all fluids
Check for any codes stored
Check air cleaner
I have them replace the fuel filter every other oil change ( This is an additional charge)
Many on the forum do all of their own maintenance. I did too when I was younger. The price is good for me with FCA coupons. Since I do not perform my own maintenance, I make a point to inspect under the hood and look for leaks on the ground regularly. There are videos online for performing the maintenance if you would like to perform them yourself.
I do my own maintenance as I find that I can do it a lot cheaper. I watch for sale prices on Rotella T6 and buy extra when it is on sale. I then send a copy of the receipt to Shell for the rebate that they have. I buy the oil filter from the dealer so they have a record of me purchasing one. The dealer here wants me to change the oil at 8k kms instead of the 16k, so that automatically doubles an expensive dealer visit. I buy the fuel filter from the dealer as well and do that change myself. Pretty easy to do with the directions given in the maintenance forums here. I look for any grease zerts and give them a few shots. Tire rotation gets a little heavy as I am not that big and with 20" chrome covered steel rims and e-rated tire it is a little awkward but doable. I will be doing gear oils this summer. Also make sure that you clean the Map sensor on a regular basis unless you are tuned. Unless you have a large pocket book I advise against for easy maintenance tasks you can do yourself with the help of the forum members here.
namretsud , you found some zerts ,???
nounofchoice , you could unscrew the yellow plastic screw under the fuel filter , to let water out
decades ago this was important , now with new garage inground plastic tanks , there is much less water contamination
and I don't read often of anyone doing it .
looking for extra work to help the truck ; you could look into this :
https://www.ram1500diesel.com/forum/ram-1500-diesel-maintenance/10259-front-wheel-bearing-failure.html
https://www.ram1500diesel.com/forum/ram-1500-diesel-maintenance/11279-wheel-bearings-another-look.html
maybe a little preventive maintenance to the 3rd brake light , before it starts to leak inside the cab .
many threads on that :
https://www.ram1500diesel.com/forum/ram-1500-diesel-general-discussion/2033-leaking.html
https://www.ram1500diesel.com/forum/ram-1500-diesel-general-discussion/7175-front-passenger-leak.html
https://www.ram1500diesel.com/forum/ram-1500-diesel-general-discussion/49266-erm-fellas-i-gots-problem-my-ed.html
https://www.ram1500diesel.com/forum/ram-1500-diesel-general-discussion/7593-cabin-smell.html
I like post # 1 in this thread :
https://www.ram1500diesel.com/forum/ram-1500-diesel-general-discussion/39778-gotta-replace-third-brake-light-bulb-will-gasket-reseal.html
https://www.ram1500diesel.com/forum/ram-1500-diesel-builds/5920-malibubtss-15-cc-tradesman-build.html#post323770
also over there : http://www.ramforumz.com/showthread.php?t=87346
Kaz, I find that if you are looking for basic truck help on ramforumz they can be helpful. But if you are talking about the Ecodiesel, not so much.
That is why I almost never go there ,
only when someone links a thread that gives info not found here ,
very rare...
I find the oil changes on this truck easier than most gassers I've done. Fuel filter is a breeze as well.
I'd recommend lubricating the front wheel bearings every 60-75k miles. This is something the dealer won't do as they're not marketed as being serviceable. Luckily we've found it easy to add grease by removing the ABS sensor.
I do my own maintenance too, the ecodiesels are pretty easy. I bought an ez flow valve to make dropping the oil simpler. I buy my oil filters, air filters fuel filters from Rock Auto 2 or 3 of each to keep my shipping cost down. I use T6 and buy it from Amazon or Walmart, wherever it is cheaper. I use Baldwin filters. I just keep a copy of my receipt and also keep digital copies too. I change right at 10k and the fuel is every 20k and I change my air filter at 20k too. I am changing oil about every 6 weeks or so. It saves me a lot of money and time doing it by myself instead of depending on a guy at a dealership that is getting paid $10 an hour to change oil.
I just replaced a wheel bearing on the right side at 169,000 miles. Can you elaborate on how you lube your wheel bearings? I had never heard of removing the ABS sensor to do grease them.
Thanks
Thanks
Pretty simple, actually. Just pull the wheel, caliper, and rotor. Remove the ABS sensor screwed into the hub assembly. Use a fitting on the grease gun that has the tapered tip so it can be held over the ABS hole firmly. Have someone spin the hub as you fill it with grease.
I do my own maintenance too, ....
... Can you elaborate on how you lube your wheel bearings? I had never heard of removing the ABS sensor to do grease them.
Thanks
first 2 links in post # 4 ...all info there .
Front wheel bearings only ,
the rear ones get lubed by rear diff oil .
Good question Pizza , now that you mention it , all images showed the dented shaft going thru the front bearing assembly ....
do we have same front wheel bearings on 4X4 , and 2WD ????.
I cannot confirm , maybe someone like Brokendownbutgood should know this ,
Generally speaking, this applies mostly/only to 4 wheel drives, right?
Should be the same for 2wd, they need front wheel bearings too.
I think the 4X4's have more force pressed on the front bearings due to being drive wheels therefore have more wear issues than the 4X2's, at least I hope:)
are you sure our rear bearings get lubed by dif oil? I know that is correct for bigger trucks but thought half tons had sealed bearings. That said I am not sure about the new models. PErhaps something changed.
yup .
i did not keep the link on this thread , a guy got stuck away from home,
truck in garage , him and his family in a KOA campground , while sorting
out who was going to pay for his burnt rear bearing ...
Noun-of-choice. You started this thread and have not come back. My noun of choice is "YOU".
You started with the impression that you can do normal maintenance on gas trucks. Well the Ecodiesel is the same truck. There is nothing really any diffferent. On the Ecodiesel the oil change is simple. Maybe easier than the gas engines as the oil filter is right up top and simple-easy to change. Now you should occasionally change the fuel filter. Most gassers have fuel filters but do not seem to need as many changes. Good because they are often real miserable to change. On the Ecodiesel you just unscrew a drain screw, drip it down, then unscrew the housing. After that the change is quite simple and that was not hard at all.
No spark plugs to change. You want trouble??? Change them out on a Hemi. You will need a blessing.
Tune the thing, add your water or DEF, check the oil and clean/replace the air filter. Nothing daunting at all.
1 - 20 of 23 Posts
