Hey everybody,
Just wanted to pass along some knowledge that I recently learned, though it may not be news to any of you. The DEF tank sensor apparently uses some sort of sonar to determine how full the tank is. Unfortunately, if you fill the tank right up to the top, it can't read the level at all: it needs some air to read properly (my only assumption is that it's measuring the speed of the sonar return through the two mediums of the water and DEF, since they would be relatively constant through differing environmental conditions, yet different from each other.).
I filled my tank all the way up, after the low DEF alert popped up in the cluster, and because it was too full, the gauge didn't move and the mileage countdown continued. After about 3 days, I topped it off again. Long story short, the counter went all the way down to zero and the truck wouldn't start. Luckily, I drove it to the dealership before I turned it off. The whole thing had the dealership scratching their heads too, but eventually they found some info about the sensor and were able to reset it and tell me how to avoid having it happen again. Hopefully this is helpful to somebody out there, and y'all don't make fun of me too much, haha!
