41 - 60 of 64 Posts
Out of a 2014
Thank you so much! I wonder if the 2016 tank is the same on top. Does that piece on the smaller looking vent just slide off? Is it all that goes on there or is there also a hose? I’m wondering if mine was put back on. What does it look like after you slide it off?
I would guess they are the same on top. The vent is white, there is nothing else connected to it.
Ok. Thanks again! Looking at the photo of the tank top,I’m wondering how hard it would be to try to see it or feel for it while the tank is mounted on my truck. I can’t check it now because it’s a blizzard!
That came off really easy, I could see how you lost it!
Ok
ok tjkoen01, I sent this photo to my friend and he said he did put it back on. He didn’t understand what I was referring to before. Thanks again for the photo!
could the location of the little " VENT " be displayed in this image I got from another thread ??
at the TOP of image , small white part at an angle , ( not in circle ) on the top view of the DEF tank ,
( most part of image taken by new tank and bottom view ) .
84665
I wonder what causes the level sensor to go bad? If we knew, there might be a way to help reduce the failure. For example, keeping the tank full might be better? It just seems odd that some are failing and others are not.
When I bought my eco, I kept the tank full at all times. You must realize that if this stuff dries, it leaves behind crystals. If you keep it full, it tends to not form any deposits. The sensor probably has a moving part that is frozen up by said crystals. I bet flushing it with warm water may free it up.
I think it's disgusting that the EPA mandates such strict emissions, yet doesn't mandate that the components be serviceable. $2000 for a def tank or DPF filter is obsurd. All these sensors and pumps and even the DPF filter should be removeable and serviceable. RAM will get hit hard for this as all US trucks WILL have a def tank failure and they'll have to replace the whole unit vs a $25 sensor. They did this on purpose to suck more money from the buyers. Glad they'll get burned by this, at least with the 2014-2018 eco's. They need to stop doing this nonsense.
The level sensor has no moving parts as in a float or arm, it is ultrasonic. It is at the bottom of the tank so unless you run it empty, there is virtually no way for a crystals to form on the sensor.
My check engine light did go out. All by itself. You were right! I have one more dumb question. Is there a plastic piece that goes on a vent I believe that is easily removed?
I think I remember my friend removing one when we were wrestling around the tank to dump it. I don’t remember if we reinstalled it for sure. He looked around and didn’t find one in his garage.
Did you have to use a AlfaOBD software and a compatible OBD interface to get the new tank/level gauge to work properly??? or did you do the swap and everything worked.
I just swapped the tank and filled it up, no resets needed.
Thanks
41 - 58 of 58 Posts
Prev
S
Sttail59
Joined Dec 16, 2019
#41 Dec 18, 2019
tjkoen01 said:
Out of a 2014
SaveShare
Reply Quote
Like
L
LoneStar14
Joined May 7, 2019
#42 Dec 18, 2019
Had my Def tank replaced under the AEM warrenty. 12-9-19
SaveShare
Reply Quote
Like
[IMG alt="tjkoen01"]https://www.ram1500diesel.com/d2/avatars/m/34/34393.jpg?1571142097[/IMG]
tjkoen01
Joined Mar 27, 2018
#43 Dec 18, 2019
SaveShare
Reply Quote
Like
S
Sttail59
Joined Dec 16, 2019
#44 Dec 18, 2019
SaveShare
Reply Quote
Like
S
Sttail59
Joined Dec 16, 2019
#45 Dec 18, 2019
My tank didn’t actually fail though.
SaveShare
Reply Quote
Like
tjkoen01
Joined Mar 27, 2018
#46 Dec 18, 2019
I don’t have the AEM
SaveShare
Reply Quote
Like
tjkoen01
Joined Mar 27, 2018
#47 Dec 18, 2019
SaveShare
Reply Quote
Like
S
Sttail59
Joined Dec 16, 2019
#48 Dec 18, 2019
Thanks for posting this photo! I’m going to show it to my friend and help him look again for it!
SaveShare
Reply Quote
Like
S
Sttail59
Joined Dec 16, 2019
#49 Dec 19, 2019
Ok
Reactions:Kazimodo
SaveShare
Reply Quote
Like
[IMG alt="Kazimodo"]https://www.ram1500diesel.com/d2/avatars/m/6/6985.jpg?1571142094[/IMG]
Kazimodo
Joined Oct 9, 2015
#50 Dec 19, 2019
SaveShare
Reply Quote
Like
S
Sttail59
Joined Dec 16, 2019
#51 Dec 19, 2019
This DEF tank looks quite different. This photo looks like the bottom of the tank. I think the vent would be on top.
SaveShare
Reply Quote
Like
tjkoen01
Joined Mar 27, 2018
#52 Dec 19, 2019
That’s the best pic I have.
SaveShare
Reply Quote
Like
[IMG alt="idoseadoo"]https://www.ram1500diesel.com/d2/avatars/m/35/35862.jpg?1571142097[/IMG]
idoseadoo
Joined Jun 4, 2018
#53 Dec 19, 2019
SaveShare
Reply Quote
Like
Kazimodo
Joined Oct 9, 2015
#54 Dec 19, 2019
same angle as in the image with new DEF tank , post # 50 , you can see the old tank behind it ,
and the vent is right there .
SaveShare
Reply Quote
Like
tjkoen01
Joined Mar 27, 2018
#55 Dec 19, 2019
Yes
SaveShare
Reply Quote
Like
tjkoen01
Joined Mar 27, 2018
#56 Dec 19, 2019
Reactions:Kazimodo
SaveShare
Reply Quote
Like
[IMG alt="Nightrainzzz"]https://www.ram1500diesel.com/d2/avatars/m/49/49045.jpg?1613579479[/IMG]
Nightrainzzz
Joined 6 h ago
#57 2 h ago
SaveShare
Reply Quote
tjkoen01
Thanks
41 - 58 of 58 Posts
Prev
S
Sttail59
Joined Dec 16, 2019
#41 Dec 18, 2019
tjkoen01 said:
Out of a 2014
SaveShare
Reply Quote
Like
L
LoneStar14
Joined May 7, 2019
#42 Dec 18, 2019
SaveShare
Reply Quote
Like
tjkoen01
Joined Mar 27, 2018
#43 Dec 18, 2019
SaveShare
Reply Quote
Like
S
Sttail59
Joined Dec 16, 2019
#44 Dec 18, 2019
SaveShare
Reply Quote
Like
S
Sttail59
Joined Dec 16, 2019
#45 Dec 18, 2019
SaveShare
Reply Quote
Like
tjkoen01
Joined Mar 27, 2018
#46 Dec 18, 2019
SaveShare
Reply Quote
Like
tjkoen01
Joined Mar 27, 2018
#47 Dec 18, 2019
SaveShare
Reply Quote
Like
S
Sttail59
Joined Dec 16, 2019
#48 Dec 18, 2019
SaveShare
Reply Quote
Like
S
Sttail59
Joined Dec 16, 2019
#49 Dec 19, 2019
Ok
Reactions:Kazimodo
SaveShare
Reply Quote
Like
Kazimodo
Joined Oct 9, 2015
#50 Dec 19, 2019
SaveShare
Reply Quote
Like
S
Sttail59
Joined Dec 16, 2019
#51 Dec 19, 2019
SaveShare
Reply Quote
Like
tjkoen01
Joined Mar 27, 2018
#52 Dec 19, 2019
SaveShare
Reply Quote
Like
idoseadoo
Joined Jun 4, 2018
#53 Dec 19, 2019
SaveShare
Reply Quote
Like
Kazimodo
Joined Oct 9, 2015
#54 Dec 19, 2019
SaveShare
Reply Quote
Like
tjkoen01
Joined Mar 27, 2018
#55 Dec 19, 2019
Yes
SaveShare
Reply Quote
Like
tjkoen01
Joined Mar 27, 2018
#56 Dec 19, 2019
Reactions:Kazimodo
SaveShare
Reply Quote
Like
Nightrainzzz
Joined 6 h ago
#57 2 h ago
SaveShare
Reply Quote
tjkoen01
Thanks sooo much tjkoen01, for your quick reply. I know this is an old thread, but still good information. I am fairly mechanical but not so much on the programing side. Your answer makes me much more confident about changing the tank myself, once again thanks!!!
Nightrainzzz , I don't see what year your truck is ??
this is for the concern about the " DEF quality sensors" not present in 2014 and 2015 DEF tanks ,
if you have a recent truck and put in a 2014 or 2015 used DEF tank ,
the ECM will not receive the info from the non-existant DEF quality sensor
and ECM will throw codes ,
maybe you already knew this ??
41 - 60 of 64 Posts
