Probably going to start servicing the drive train on my old man's 2018 Cummins. It is a 3500 SRW 4x4 with the Aisin transmission. Hoping someone has done some of these and can lend some info.
The front/rear dif's seem pretty straight forward, but do they have drain plugs?
On the transfer case. I see the manual recommends BW44-44 transfer case fluid, but I thought i could use ATF+4? If so does the Valvoline MaxLife Synthetic ATF in the redish jug work for that?
Lastly the transmission. What have yall used? I was hoping to be able to use the same Valvoline MaxLife Synthetic I have used in everything for the last 20+ years, but not sure it will work.
Thanks
Thanks
