1 - 20 of 20 Posts
That sounds like something better left until after the warranty runs out. My .02
Farmers and Ranchers like them because there extremely useful for loading hay,feed, chemicals ect.most likely a flat bed would not affect warranty, our dealer installs them it's a country thing. And the nicest flat beds I've seen are the ones on the Home Depot rental trucks they're aluminum and sides are on hinges nice!!! You can buy a steel flat bed pre made for about 1200-1500.
What is the weight difference compared to the stock bed? If it's heavier, then the already payload-capacity challenged Ram will struggle.
I have to agree with robertm. The auto manufactures put these ratings on for insurance porpoises to cover their asses. I don't know one person with a truck who has EVER worried about payload. and I have yet to see anyone break anything on their trucks because of it. I remember when I was a kid where I grew up there was an old farmer who had nothing but 2wd trucks, and in the winter time for sufficient weight, he would load a full size round hay bale in it. By the way he had half ton trucks. I myself have loaded my old half ton Chevy down with so much fill dirt that the receiver hitch would bottom out on bumps, and also hauled a load of 12 full sized railroad ties. never had any issues except with the rail ties I couldn't go over 35 mph because the front end would start to float around too much.
Probably best left for the larger frame and suspension of a 2500 or more. That's not only for load capacity but type of operation.
Farm equipment is normally slow speed, long idle-time operation. Not sure any of the current diesels are well suited for that type of operation. Certainly, the way the V.M. Moteri is emissioned and EGR'd, doubtful.
You make a good point captain. Once the 'off highway' tuning deletes the emissions and egr it'll be set. If they aren't air suspension they'll make one really nice ranch truck.
Actually pre made flat beds are a lot lighter in general because pre made flat beds are thin and cheap metal what makes everything heavy is when you add a fuel tank , tool boxes, ect then it adds up quick!!! And a good custom flat bed cost a lot more than a pre made .
And to take a bed off a truck is extremely easy usually about 8 bolts and unplug tail lights and filler neck 3-4 people and its off .And just to add to this it is much easier to remove the bed if you have any fuel tank issues to work on it IMOP
my thoughts exactly, if for heavy load and work use then a 2500 or higher would be better suited
This guy, I believe, has two EcoDiesel trucks with flat beds. One is a regular cab and the other is a quad or crew cab.
That is awesome. I'll do this when it becomes my ranch truck..Did it take you 6 years to find these photos.? Lol
I've had the photos for a few years, but I just found this thread. 😉 I've been thinking about converting my 2015 to a flatbed. When looking for ideas, this thread came up in a google search.
Reactions: Ecosparky
Here's another photo that I saved:
I found another 1500 with a flat bed.
Reactions: Dennisvab
1 - 20 of 20 Posts
