1 - 9 of 9 Posts
Hey all,
My 2016 Ecodiesel HFE has shift controls (+/-) on the steering wheel, but it doesn't let me lock the truck in gear. For example, I want to keep it in 8th gear on the highway, and if I give it more than 10% throttle it downshifts into 7th. It is a diesel, and should be handle some additional load in 8th gear. In order to get optimal fuel mileage, I am in a constant battle of trying to keep the truck in 8th gear which is extremely frustrating.
All the shift buttons let me do is:
1. Stop the vehicle from engine braking when going downhill
2. Select a maximum gear for the truck to upshift to.
I believe GDE sells a transmission tune that allows you to take full control of the shifts, does anyone have experience with this? Or is it only my HFE model that doesn't let me take full control of the gears?
Any thoughts/insight appreciated.
It's not just your HFE, all stock transmission tunes work in that manner.
I have the GDE trans tune. It will do what you're looking for. I requested they add the option to have the gear indicator always on. Handy to always know your gear even when the computer is shifting for you.
I love the trans tune, it's a great compliment to the ECM hot tune.
The stock truck will lock out upper gears above set point but not force an upshift. Truck doesnt need to upshift unless it's in a position to do so, which in my opinion it does too fast anyway but that's the mpg tuning (in theory). A quick tap on the minus button will show gear allowed and gear it's in. If you always want to know what gear it's in, just hit the minus and then the plus up until it says 8. You can see what gear it's in as it will show up and downshifts.
Discussion Starter · #4 ·
Thanks for the info. I will likely get the trans tune. Is it just a reflash? No hardware required?
If Ram is going to reflash everything when I take it in for the settlement updates in a few months, will it get rid of the trans tune? And can I re flash it? Or does GDE somehow incorporate a one-time-use into their program?
GDE will give you a tuner that will have the trans tune on it. You'll first download your original trans tune to the tuner module and then copy the GDE tune to your truck.
When you take your truck in for the engine flash you'll want to put your original trans tune back in the truck, take it in for the EPA-mandated flash, and then put the GDE tune back on the trans when you get home. If you get the GDE engine flash before the settlement update it will be written over - of course if you have a spare ECM with the GDE tune on it you can just swap it back in when you get home.
Bob
Bob
The GDE trans programmer dies not come with the trans tune preloaded. When ou receive the programmer, you first update the programmer's software. then hook up to your truck and copy the stock trans tune. Email the stock trans tune to GDE and they promptly email you back with the modified tune for you to upload to the truck.
I don't believe GDE knows if their tune will work post-AEM until they've had time to analyze the AEM and how it will work with aftermarket tuning.
Banned
Hey all,
SFT Transmission tune. $400 and you'll have control over your shifting.
1 - 9 of 9 Posts
