1 - 6 of 6 Posts
Hello, I recently picked up a CTS2 for my 2015 EcoDiesel and plugged it in to the OBD and got nothing. I tested the OBD plug with another OBD style tool that in fact, powered up right away. As well, I plugged the CTS2 into a 2016 Ram with a Hemi 5.7L that it came on right away with.
Took the CTS2 back and tried another, which did the same thing...
Anyone have any ideas or suggestions I might be able to try?
Thanks!
Did you try it with the truck turned off, plug it in and start the truck to see if that will start it up? If not call Edge.
Should turn on. Something just might not be right with your OBDII port. Have the dealer check it out.
Try updating it from your computer. I heard something about the 2015s ECD needing an updated version on the Edge. Worth a try or get in touch with them for resolution.
1 - 6 of 6 Posts
