After being GDE tuned from 40K, I finally decided to remove the EGR at 155K. Overall a pretty manageable project right until literally the last bolt. Removing the turbo up pipe, one of the bolts chewed up the threads in the hole. Putting the new screw in it shredded the threads and can’t get a screw in. That was bad, and has now gone to worse. I tried tapping the bolt hole but with the crappy access. Ack there I mishandled the tap and snapped the tip down in the hole.
I’ve seen some threads with people talking about shearing bolts back there and drilling and welding to fix it. First of all I’m not sure if my 2014 has different clearances, but I can barely get a hand back there (passenger wheel off and plastic fender removed) let alone drills and stuff. I’ve seen a tap removal tool online but I have little confidence I’m not going to make it worse. My limited skill set is “tapped out”.
Two bolts are nice and snug. Should I just use a cold weld epoxy to reinforce the plate at that corner? Any other big brain solutions out here?
