My compressor went out so I replaced the compressor, valve block and all four shocks, checked and confirmed no leaks. Off-road 2 on my 2015 Laramie Limited won't work due to excess payload warning but the truck is empty. I attempted about two dozen times to calibrate the suspension using the rear lower control arm bolt to ground on the front and the forward lower control arm bolt on the rear. My calculation between ground and Center spindle is 15.5 inches. Any calibration settings I input into Alfa OBD give me excess payload warning and off-road 2 unavailable. Had an appointment at the dealer who canceled when I showed up for my appointment and wants to schedule 8 Days Later so I said screw it.
Anyone deal with this before? Ride height sensors? Control module?
