Here's some posts on engine shudder hat may help. Search results for query: shudder
That, is your clue.The dealer has no clue.
Hi: Ktdea423... Here's a clue. It could be dirty fuel injectors. Simply try a dose or two of Hot Shots www.hotshotsecret.com in the fuel tank. I don't work for them but use the product. The dealers(parts changers) don't recommend it cause they're to busy making money to. It's like a laxative for your truck... and it works!!! Makes the going great.2016 ram ecod
I’ve had this problem off and on for a year. 12000 dollars later still same issue. The dealer has no clue. At random times it stutters. Some days it’s all the time others it’s nothings. They replaced the fuel pump and high pressure.
fuel filter. Nothing fixes it.
im hoping someone can help here.
if I step on the gas it will go away. Or let off the gas. Any advice is appreciated
I've looked around with no luck, where are you getting the Hotshotsecret? Ordering on line or any particular store? thanks.Hi: Ktdea423... Here's a clue. It could be dirty fuel injectors. Simply try a dose or two of Hot Shots www.hotshotsecret.com in the fuel tank. I don't work for them but use the product. The dealers(parts changers) don't recommend it cause they're to busy making money to. It's like a laxative for your truck... and it works!!! Makes the going great.
Hi: Patroller8D... I get mine at our local "Truck stop". A bottle last a while at 8 oz. every 6 months but that's OK.I've looked around with no luck, where are you getting the Hotshotsecret? Ordering on line or any particular store? thanks.
