1 - 14 of 14 Posts
I purchased this HD Diesel tune in November 2019 and just sold my 2018 Bighorn.
It has the EGR delete and cold temperature fast idle option.
I have all the original receipts to go with it.
Asking $700 shipped and insured.
$500 Shipped and Insured!
If interested, please email me direct at:
[email protected]
Pictures available upon request!
Alfa ODB can change the Vin/Injectors Really easily (did it on my GDE) and I am not very mechanical/electrically inclined
Thanks for sharing this information....
And YES it is still available!
I'm surprised that no one out there has purchased it yet!
2017 Laramie eco about to be tuned and deleted at 30k. Forget that it’s now hp tuned and deleted.
HD does everything on their handheld now. I suppose that would work if you could change the vin
2017 Big Horn EcoDiesel, 4WD, Bilstein leveling kit, few mods here & there....
Has this been verified? Hate to purchase a brick. I have AlfaOBD to do myself if this is possible per the company.
Sent from my SM-A716V using Tapatalk
Yes alfa can change ecu vin code and injector codes which you need to do to swap ecus....I've used 2 different gde ecu since purchasing my truck + stock. If the sticker for injector codes isn't there make sure and pull them thru alfa before initiating swap
Vodoo37 - do you have the instructions for changing the VIN and Injector Codes you can send me?
Try this link for programming vin and injector codes using alpha OBD
Not off hand I believe there is a alfa thread that has all of the options\how tos i can try and see if I can find it after work. You should be able to do a search for alfa
1 - 14 of 14 Posts
