41 - 47 of 47 Posts
Discussion Starter · #41 · (Edited)
ever get that photo of your modified fuel filter removal tool? I'm planning to do the same as you but with a Fumoto valve with nipple for a drain tube. May use a band style filter removal tool like this?
I ended up 3D printing an adapter. I'll take a pic of it when I get home. I used it once, it fits, but is tight and needs to be sanded down a little to widen it out. Last filter change I just used a rubber strap wrench. Similar to what you posted a pic of, that works even better.
Here are a couple pics of my CAD model.
Discussion Starter · #42 ·
Here are the pics of my 3D printed fuel filter adapter.
Reactions: 97hmcs
That is quite amazing! I put the brass plug in mine, but I would prefer to put in a drain valve. I have the fumoto oil drain and that thing is just too convenient! I would definitely be interested in this adapter.
Just installed a Fumoto oil drain valve...last time for a messy oil change. Top loading filter + drain valve - an enjoyable oil change.
I too would be interested in getting an adapter. I’d even video the job to show others the value in a valve on the fuel filter housing vs the lousy yellow plug or the brass plug. Be happy to pay for an adapter!
Discussion Starter · #45 ·
Well I guess I could sell the one I have. I didn't think about making more and selling them. Right now I can't make any more as our 3D printer at work took a dump. Not sure how long it's going to be out of service. Do any of you have a 3D printer? I could email the stl file?
Just changed my fuel filter for the first time today. After loosening the drain screw, like others have said only a few drops came out. All I did was tap on the housing a couple times with my finger tips and it started draining a steady flow.
I still used a Ziploc bag when unscrewing the housing and some more fuel came out, but only a few ounces.
Hey do you still have the 3D STL file available? I can print a few of these out.
41 - 47 of 47 Posts
