1 - 9 of 9 Posts
Well, thanks to a lot of information from here, I did the full fluid service today.
Differentials, Tcase, transmission, oil and coolant.
Having just done the V08 and a couple recall items, the dealer advised all these items were due at 100k. They would happily complete all the services for about $1190! I told them to stick with the recalls and I would handle the rest!
So today, I tackled the lower radiator hose due to a small leak and went back with new coolant. Next, knocked out oil, tcase and diffs.
Transmission temp was down to 80ish, so I started up, got it to high 140s and went to work. Drained, reinstalled new filter/pan and began the fill procedure. Pumped in a little over 3 quarts and closed it up. Validated correct temperature range, ran through the gears and rechecked. Three pumps later, it was full. In under 5 hours, I completed all the services and saved about a grand!
One thing I did notice, while installing the lower radiator hose(s), actually 3 with a plastic T, it seemed like the intercooler hose was loose. It was rigidly attached but could be turned and wiggled. Almost like the boost pressures it tight. When I started the engine, it was noticeably more solid, but just didn’t seem firmly attached like I would think.
The transmission should have taken 5-7 quarts with a new filter. The intercooler pipe does have a loose fit that seals with an o ring at the intake and the compressor discharge.
That’s what I was thinking on the transmission. Checked it twice, but better do it again just to be safe.
Did you have to lift it to do the tranny?
Fortunately, my neighbor has a lift in his barn, so it is very convenient.
However, it could be done easily without a lift.
Depends on how well you fit under the truck. Doesn't require much room, running all 4 tires up on some boards would be plenty.
What made my tranny service soooo much easier was making my own fluid transfer pump. Picked up a 1gal pump sprayer from Home Depot for $10. Added a cheap plastic ball valve and some 1/2" clear tubing. Put a plastic 90º fitting on the end to fit into the trans hole and keep the hose away from the hot exhaust.
I used a $8 PITTSBURGH AUTOMOTIVE
Multi-Use Transfer Pump from harbor freight when I did my differentials. Worked great.
Many thanks for your post, upon re-checking, I was in fact low. End up with about 5 quarts, so I was 1 quart low.
1 - 9 of 9 Posts
