1 - 13 of 13 Posts
Something had to have gone wrong on TFL's latest test of the Gen-3 ED MPG's. Granted it is a quad-cab two wheel drive which should be a good mileage maker, but IMO their empty MPG numbers can't be right. I'll be watching for the follow-up run.
Just think if we could just tell the EPA to stick it, it would probably be closer to reality than the number they were thinking lol.
The last run result was probably a fill-up anomaly. We can probably can rule out a weather anomaly creating a tailwind for the entire loop as the dashboard's mpg would have much been higher.
Mileage aside, I didn't realize they were putting a 33 gallon tank in the 2020. With the highway mileage on my 17, that means I could be pushing almost 900 miles a tank! With their 40 mpg unloaded, that pushes it up to 1300 miles.
I've been thinking about this some more. Either they have already run the second loop & confirmed the numbers "Why would they have posted this if they hadn't confirmed them?" or they did have a screw-up at the pump & maybe used a different nozzle that clicks off differently. The follow-up should be interesting.
agreed. they definitely had to either do a re-test (and not post yet to generate more web views + revenues) or they have anecdotal driving history with their time with the truck to not be embarrassed later on by a competitive journalistic outlet....
I'd be shocked if FCA did not have some bare minimum stipulations & controls over what can be disseminated on a pre-production vehicle that is done using a courtesy loaner. FCA has an interest in ensuring their brand is discussed accurately.
I also wonder if they were limited to the amount of time they got to spend behind the wheel. If my numbers were that far off of where I anticipated, I would have repeated the test right then.
That is flat out nuts. What is impressive to me is both the fuel mileage trailering and that 33 gallon tank. Oh my I would sure want one like that.
Discussion Starter #11
IMO to be accurate they would have to do the re-test on the same day. That's the only way they could have as close as possible the same road, wind & weather conditions as the first test.
Captainmal: I'm with you on the 33 gallon tank. The one I order will definitely have the big tank.
You've got to give the TFL guys some credit though. They sure have all of us talking about their video & waiting to see the follow-up.
The 33 Gallon tank is a big thing I miss from my last truck with a hemi. That extra bit of fuel in the eco will mean I wont have to stop for fuel once when visiting friends in the next province (1000km total) or when I make my most frequent work trip (1200km each way), awesome.
No doubt that's their goal for increased advertising revenue. Some might argue it's better to confirm the sensational before publishing a video.
1 - 13 of 13 Posts
