2015 RAM 1500 Laramie Ecodiesel fully deleted 6"lift 35" venom terra hunter
Ok this may seem odd because it does to me to. Has anyone else had an issue with you trucks RPM's getting "stuck" high when going from stopped to full throttle? So its happened since i have owned the truck. i went to pull out on the highway rolling into it at first then seeing a car fly up on me. i stick the throttle to the floor "basically" and you can hear it start to kind of spool and once it wanted to really take off under boost the RPM's shot up to 3500-4000 and stuck there. it almost sounded like the truck was in neutral and i was on the throttle. i pushed the peddle down more and there was no response. i had to fully let off the throttle let it die down and basically sounded like it finally shifted and i was able to get back on the throttle and go. this happens anytime i want to go from rolling or driving slow 35-45mph to flat out full throttle. It is almost like its boosting to much for and the computer cant comprehend what is going on (Boost PSI 22-30 at full throttle). Any thoughts out there? Anyone else have this happen?? its not a big deal as i have learned over the last year to ease into the throttle to full throttle and it is just fine.
I have a 2015 ram 1500 Ecodiesel fully deleted, unknown tune(tuned and deleted before my ownership), intake tube delete, cac delete, cold air intake, 6in lift on 35in tires.
