The service rep said my DEF injector should arrive today and they will install the new SCR and Injector tomorrow.
I hope they followed the following procedure for the SCR failure.
Remember this is from an electrical engineering viewpoint.
Auxiliary Cathode and Gate Leads not Twisted
If the auxiliary cathode (small red) and gate (white) are not twisted together properly it can cause false triggering or the device turning on when it should be off. The proper twist for these is one twist per inch. This eliminates EMF (a.k.a. noise).
Loose gate connection at SCR or terminal board.
This is typically caused by improper or non-soldered gate connection to the device and/or firing board. It could also be the result of improper matching of connectors. That is, metal or plastic undersized male connector fitting into female connector. There were incidences when they used 3/16” male with ¼” female. This will create heat (40 volt potential), which in turn melts solder to the terminal board and breaks the connection.
Bad snubber (R&C) network across SCR.
Snubbers are resistor capacitor networks (circuits) which limit rapid rises in voltage or current in short time periods. If the snubber network is malfunctioning or not designed to handle the load ( as some of the older units did), spikes can be passed on to the SCR causing failure.
Cold solder joint.
Cold solder joint on either the gate drive circuit or the snubber network are suspect to poor connections. Again, it boils down to getting good connections, avoiding heat build up and making sure there are no spurious paths for the current to take.
Bad firing amplifier.
A SCR may show that it is not conducting when it should be. This may be caused by insufficient, or no gate drive caused by a bad firing amplifier.
Small crack in the printed circuit board electrical circuit.
One of the more frustrating and hard to find problems is a small crack in the printed circuit board circuitry. This shows up as an intermittent in the system and therefore is difficult to trace.
Improper torque or pressure.
When conducting current the silicon chip, or junction, within the SCR package generates a great deal of heat. In order to get the heat away from the junction, it is imperative to torque the stud type SCR’s to their specifications listed in our catalog.
With Hockey Puck or disc type SCR;s, making sure there is good heat transfer is a function of pressure, in pounds per square inch (PSI), applied to the SCR. Again this varies with the size of the package. It is also very important that all interfaces are parallel as you alternately tighten the clamping nuts, ¼ turn each, until you reach the proper pressure.
If the junction overheats, the SCR will continue to conduct when it should be off, thus causing major circuit problems.
Loss of cooling.
The system cooling can either be liquid or air in conjunction with a pump and/or fan. If the cooling system fails, from clogged filter, loss of coolant pressure, or airflow, then the entire circuit is in danger. Significant heat is generated by these components and overheating will eventually cause junctions to start failing.
Insufficient gate drive to the SCR.
SCR’s need a hard drive to get the total junction on and ready to accept the system current. A hard drive is typically an initial gating pulse of 25 volts at 1 amp for 1 microsecond then rapidly decaying to 3 volts and 500 milliamps. If the gate drive is insufficient to get the total junction on thin when the system current pulse occurs it will hit the portion of the junction that is on. This can cause a current burn through destroying the junction thus causing a device failure.
Cracked Insulation.
Old insulation that has become cracked can cause a short circuit under normal operating conditions. This will cause massive failure of electronic components including the SCR.
In summary, SCR’s will not fail by themselves. Something external causes them to fail. Before you pullout the failed SCR’s and install new ones make sure you locate the cause of the failure. Check the above ten possibilities. If you still don’t know the reason, have the failed devices analyzed to see if the junctions will give you an indication of the failure mode.
