1 - 9 of 9 Posts
Got a message on my dash this morning saying one of my tail lights was out. I got out my owner's manual when I got home today to look up the bulb number. The manual listed one but also said if I have the "premium" tail lights, I have to go to the dealer. So I looked at my window sticker and I have premium tail lights (2014 Laramie Longhorn that hit 130,000 miles yesterday). I've been looking at prices on line and the cheapest OEM replacement I've found is a little over $200 (believe the part number is 68093078AC).
Has anyone else had to replace on of these expensive lights and, if so, did you find a better price?
Thanks!
Dave
No problems on my Laramie. Try resetting the message.
Do you see any LED's out?
I didn't see any LEDs out but I need to ask my wife to check while I press the brake pedal. I don't remember if I saw the message when I started the truck after work but I'll watch for it in the morning.
Dave
99.9% it's the 3rd brake light.
So to follow up, each time I start my truck, the instrument panel display tells me my right brake light is burned out. I finally got my wife in the truck to push the brake pedal for me. It is the CHMSL that's burned out. The owner's manual gives a number for the bulb but also says if you have the "premium LED" CHMSL, you have to go to the dealer. Pretty sure I can see a bulb behind the lens. Fingers crossed it's a $5 bulb instead of a $? LED assembly!
Dave
Dave
put the four way flashers on and the parking lights on and get out and look and see what you see.
My rear tail light also failed today. Dealer is day my it isn't covered under my extended warranty, so I'm stuck paying $400 for an entire LED assembly.
Anyone have an resolution to this. I also bought the top tier extended warranty, and have 2 years and 55,000km remaining on it.
Dave
Or a broom stick (etc) wedged between the pedal and seat.
1 - 9 of 9 Posts
