1 - 7 of 7 Posts
2017 Ecodiesel Laramie
If you were to purchase a tune right now for a 2017 Ecodiesel 3.92 gears, which route would you go? Pre-owned GDE tune or HD Diesel Supply?
Thanks for your opinions!
New HD , Reasons you don’t know which tune you’re buying if it’s a used GDE, Because GDE kept upgrading and fixing little bugs along the way with the tuning.... My early GDE tune would occasionally throw a pesky cel , I didn’t bother sending it back, was easy enough to just erase cel with my Edge...
The tunes would be nearly identical, might come down to which options you want with your tune like regen msg, high idle, turbo brake. Cost could come into play as well.
Thanks, @Bounty Hunter .....how critical is it to get the right year in your opinion? I have a 2017.....I think I have read you can put anything from a 2014 on in a 2017 model without issue....is that correct?
Yes, that's my understanding as well.
1 - 7 of 7 Posts
