1 - 11 of 11 Posts
Hey guys,
Was driving into work this morning and P26AB came on. Drove fine no issues that I noticed. I got home today and it didn't clear so I opened the hood to take a peek and I'm wondering if its a blown head gasket now.
I noticed my coolant reservoir looked dark and when I opened it it looked like foam or sludge. After dipping my finger in it looks like oil. I checked the oil and its low but doesn't look like coolant is in the oil on the dipstick or anything.
Is this likely a head gasket? I only have 160,000 km on the blood thing so this pisses me off. I just had the rad, oil cooling lines and stuff replaced 4-6 months ago so is it possible that something they did during that service caused it? I really don't want to be looking to buy a new truck after I paid this thing off.
Just wondering, I'm looking at my repair bill for the EGR recall which was done in March this year. Wouldn't this have been replaced then? I see right on the bill it says cooler.
The recall was for the EGR cooler not for the oil cooler. The replacement of the oil cooler is not hard, there are 6 bolts holding it, the hard part is to flush the oil out of the cooling system.
The oil cooler and filter assembly with new filter in it runs for like $200, just for the part.
Am I reading this wrong then? There was several things done at the same time.
Basically in an oil sample High Sodium is going to an EGR cooler and high potassium is going to be an oil cooler. good luck !
The P26ab code is for the three way valve sticking which is commoly caused by an oil cooler failure. Your symptoms sound like a classic oil cooler failure. Stop driving it and change your oil cooler and flush the cooling system. New oil coolers can be found online for a smidge over $100 now and there easy to change.
Looks like they installed a new cooler, which is most likely failing or they messed up the install/gasket when they did it. Take it back to the dealer and have them check it. If the new cooler is bad they should cover its replacement I would think.
Reactions: Dennisvab
1 - 11 of 11 Posts
