1 - 9 of 9 Posts
I just went to turn on my 2015 Ecodiesel and this is happened!!!!
It throwing a bunch of codes
Any idea of what happened????
Check the big plug under the drivers door on the frame. Squeeze it back together
Also checked the BCM connections that are below the dash, sort of behind the brake pedal
they look like this :
the smaller one inside the cab will tend to give you more of a black screen dash,
the big one under the truck is more likely to be responsable for your symptoms,
did you drive thru a big puddle by any chance ??
Do you use Torque Pro at all? If so there are scenarios where it will cause these errors
^^^ good point
If the Torque App is being used(or any OBD reader app), you need to lock the vehicle profile OBD comm to:
ISO 15765-4 (CAN 11bit/500k baud)
1 - 9 of 9 Posts
