1 - 19 of 19 Posts
Ok Guys and Gals,
I dropped my truck off yesterday morning and didn't want or need loaner so the dealer gave me a 40 mile one way ride home. In addition to the emissions recall I have battled P26AB for 2 years or so that came up and got canceled and I wanted the 3way valve replacement before my extended warranty ran out mid June. I also opted to get my last prepurchased oilchange about 1200 miles early to avoid another trip to the dealer soon since I expect to trade the truck when I can order a 2020 this summer and won't put enough miles on it for another change anyhow.
Also, my truck is factory stock with all work, except brakes done at the dealer and no aftermarket tune. It has the 3.55 and stock 20" wheels and a replacement set of SR-A tires. Mileage was 77345 when it was at the dealer.
Dealer called yesterday afternoon and confirmed a 3way valve replacement was ordered. This afternoon they called and said my ride to pick up the truck would be here in about 45 minutes, and it was. Got paid my $100 deductible and signed the paperwork and went to the truck with the dog. Looked at the paperwork and found the following
1-3way valve p26AB warranty repair and replacement noted
2-Prepaid oil and filter change done
3-Recall U53 performed reprogramming ORC module
4-U07 recall performed reprogrammed PCM and TCN @ current level and reprogrammed RFH per recall U07
5-Recall V08 performed. Reprogrammed PCM from 68306456AC to 68308456AH. Perform oil life data exchange. Reprogram TCM from 68234053AC to 68234053AH per recall 08.
If anyone can help decipher the gibberish in item 5 above I would appreciate it. Particularly the oil life data exchange comments.
Anyhow, I started the truck and it sounded and behaved as before. Went to check to see if the oil change screen had been reset. It had not. The dealer had always done this reliably in the past. I tried to reset it and was told I had to do it with the engine off but the ignition on. I tried that and after following the first instruction successfully the next step was 'confirm you want to reset and push>" I pushed > and it wouldn't reset. I started and stopped the truck a few times and tried to reset it but failed. This might be a bug in what was done. Can anyone else that has gotten the new emissions tune confirm whether their oil life reset works? I have to drive by the dealer tomorrow so will stop and ask them too. I did take a sample but have a few other oils to sample and will get them all sent in as one in week or so and will port results then.
I drove home about 35 miles on a road I drive many times a week. Truck accelerated and behaved as it had beforewith a couple exceptions which I will list below. Computer mileage indicator was consistent with what I had seen previously with about 700 ft elevation rise on the way home. The truck never was a drag racer off the line but was as responsive as before. As always it seems to stick in 3rd or 2nd gear too long and can feel doggy at low speeds and that hadn't changed. That said when I floored the throttle it jumped down to low gear and took off like a scared rabbit and I went to 80 mph with the throttle floored and it upshifted at about 4000-4100 rpms on the way up. No difference and it did not come apart.
My 2 cents worth is that those that report no acceleration and no downshifts and no performance either have trucks with other problems, don't recall what the original factory tune was like if they had GDE or have another motive other than honesty and their best attempt at an objective comparison.
So what was different, recognizing that the truck had been driven by the dealer and it wasn't a cold start. Water temp was 115 a bit after startup.
1-On the upshift it stayed in gears 6 and 7 longer than before. This made it feel peppier in the midrange on the highway. It will take more driving and time to confirm this and see if it affects mileage noticeably.
2-Once it got into 8th it seemed to stay there the same as it had before.
3-In my initial departure with a gradual coming up to 55 mph since there was no rush from traffic is seemed like it stayed in all the lower gears longer than before. After a couple miles I pulled off the road and stopped and then started again and it felt the same as previously. I normally start off on hilly and curvey rural roads so we will see what it is like tomorrow morning when I start from home
I have tried to be clear, diligent and objective in what I have written. I am happy to answer any specific questions about the above and, as stated, would appreciate any insight anyone has on the dealer notes for item 5. I will park the minivan for a week or two and drive the truck exclusively and see if my impressions change and what the mileage does. If I notice anything I will post it here.
Now I will pause a moment before I post this so I can put my personal armour on since it seems to me, on first impressions, that the new tune is a non event. My impressions could change and if so I will report them here.
All the best and enjoy your 3 grand and a few beers plus the added warranty!
I got mine back today. Although mine went a step further then just a reflash. My computer shot craps on the programming and had to be replaced. Much like your truck oil life was at 0% and didn't want to reset right away. But did notice a little rougher idle at startup but smoothed out. Throttle response pretty much the same. But I like you roll into the throttle instead of treating it like I just saw a spider. Shifts where smooth. The only thing different was on starting the shutters closed and stayed that way for a while before reopening. Unlike before where they shut then reopen. All temperaturesales where the same but tomorrow is the test. Drive 90 miles round trip to work. Then go pick up camper. That's the real test.
I know the "Reprogrammed PCM from 68306456AC to 68308456AH" is the part# change of the programming(yes the programming has a part#) for the PCM, same goes for the TCM (which is your Transmission controller).
I can check with my neighbor but I think the oil life data exchange refers to maintaining your current oil life percentage when they do they flash the PCM.
I can confirm that it had the same 12% oil life remaining when I got it back. Unfortunately I could not reset it and I expect the garage couldn't either since they have always rest it in the past. I'll see what it is like tomorrow after it has a cold but good night's sleep outside. Thanks for the info Crash, its always useful.
Ok Guys and Gals,
look at number on module , did you look if you had a new different sticker on the ECM
behind the Air filter box . when trucks are new they only have the sticker saying BOSCH on them .
those long numbers are the version of tune in ECM/BCM , and in TCM ,
6823XXXX XX on the image sticker here , was applied to the ECM , looks by your description
that it is the software in the TCM that starts with 6823 .
Does it make sense ???
For oil life , when you press to confirm , some reported they had to press twice .
Yes, there is a new clean sticker over the original sticker with the Bosch on it.
Ref the oil life reset the instructions on the screen say hold > to reset. I do that and then the screen says push > to confirm. I push it once and it jumps back to the original percentage. The second screen also gives a pictogram to show you can push up or down to cancel the reset. I tried pushing it twice quickly and that makes it jump to the next screen which is voltage so noting works.
Back in 2014 on my first oilchange they did not reset it and to the best of my recollection it was easy and I just hit the > once. I think I even did it while driving so it seems to me somewhere along the line they changed the programming on the reset. That makes sense to me since I can imagine there were accidental resets happening.
I also noticed the coolant is quite low. I suspect they lost some when they changed the 3way valve and forgot to top it up. Anybody who has done this please post a comment on how much you might lose when doing this.
Do remember that you can't have the engine running to re-set the oil life. Make that same mistake literally every time I change oil. Slow learner or worse as i keep doing it.
Lots of stickers on that ECM. Later this Summer is when I will probably get that tune. Not happy to deal with removing the water from the DEF tank and adding DEF. Then I will have to get the darn thing home, park and remove the ECM to send to GDE for another exchange. Luckily I have another car and motorcycles to use if I need to go anywhere.
.... Then I will have to get the darn thing home, park and remove the ECM to send to GDE for another exchange. Luckily I have another car and motorcycles to use if I need to go anywhere.
You seem to be organized Captain , once you have the date for your planned AEM , just get GDE to send you the Updated Tune in a different module
to arrive a couple of days before the date of the AEM , when you get back home , switch , and send back present module for GDE to refund the core
charge , you have 21 days before the value drops , usually you will see the charge on your credit card and the refund also ,
all that activity before the credit card bill is even sent to you .
bottom left here .:
https://www.greendieselengineering.com/ECM-Service-Update/GDE/Ram-1500-EcoDiesel-Tune-Update/2_46.action
Emptying DEF tank ,
-drive truck on a couple of stacked pieces of wood , under each wheel , for belly clearance.
-slide under with drill and drill pump ,
-remove tube as in video , I did it on my 2015 , easy , even with tank full , there was no DEF coming out
I was on level ground .
stick tube in hole and search for water to remove by moving tube around
hole is near the back of tank , I guess you could arrange for the front of the truck to be higher
so that your water would be and the backof the tank to get it all out .
link to pump :https://www.homedepot.com/p/Everbilt-300-GPH-Drill-Pump-Kit-PUP63-HD/204667248
and video :
Well sounds like you're truck is going smoothere then mine now is. I went to go to work this morning and start was normal but end was horrible. It ran great till the highway then no cruise, and 2 miles later bong check engine light. Well SCR system is now bad and has to be replaced. Already usin that new Warranty.
Howie and Capt I've have the same problem resetting the oil indicator and always have to get the book out. After you press the steering wheel buttons to reset and ok you have to turn the key on to the run position without starting the motor, and then press the accelerator pedal three time within 10 seconds, and then turn the key off. Turn key back on and evic should show 100% on the oil indicator.
FYI. My retune is working as it should now. Looks like the dealership forgot to reinitialize the ecm after performing the eco reflash. I ran through the GDE initialization steps and now the truck runs great. Wish I had thought to try that a few days ago. My truck has been in the garage with the hood up since Sunday. My GDE tuned ecm should be arriving today. Ill install it then get on with my rock hounding trip.
Discussion Starter #13 (Edited)
My updates,
1-Oil life is now reset. I did not interpret the reset instructions correctly. First you push and hold > to reset. Then the confirm screen comes up. DO NOT GO DIRECT TO PUSH > TO CONFIRM> YOU MUST FIRST SCROLL THE SCREEN UP OR DOWN TO GET THE OK IN THE CENTER WINDOW THEN PUSH > TO CONFIRM
I am sure a gamer wouldn't have made that mistake.
2-Dealer added a quart and a half of coolant. Claimed they had topped it up but that sometimes they trap air and burp a bit.
3-I did about 90 miles today on a route that I do once a week. Truck ran great and mileage seems about the same but it was a bit windy today so hard to tell for sure. It seems like all the upshifts occur at a higher speed than before and at 55 any throttle pressure or grade drops it to 7th. Truck actually feels peppier due to the later upshifts. It seems it should negatively affect economy. DOn't see it yet but will see how it does over a longer perio5.
4-Startup was at 40 degrees F and start was normal. I have an awkward first mile with several sharp curves and short steep up and down hills. I typically do not go very fast and that trip always caught the transmission in too high a gear and didn't want to shift down. I either had to step on the accelerator a bunch or just a bit and wait for the truck to slow on the uphill and then it would make a downshift. It still did the same thing this morning and I can imagine that characteristic could frustrate people. It doesn't do it when it is warm and it downshifts easily. My SOP is to manually control the gear it is in for the first mile.
It will be interesting to hear impressions on shift points from someone with a 3.92.
All in all the new tune seems OK. I will add any significant different and new impressions here.
Discussion Starter #14
I have another 135 miles and impressions remain the same. Did some different routes and had a better chance to evaluate 7 to 8 shift points and it has definitely risen. When new it could be enticed into 8th as low as 45 but often in 8th at 50 and quite happy. With the oil spec change update I believe the shift points rose some and it had to be enticed to be in 8th at 50 but was nearlyalways there at 55. Now it has to be enticed to get into 8th at 55 and with any load increase it shifts down. FOr me the overall feeling, probably because of the shift points is slightly peppier.
Hard to tell on the cold start issue since summer is finally coming and temps below 60 in the morning are now rare. Fall will tell me more about that issue.
All the best,
Discussion Starter #15
After another 4 weeks and about 800 miles no change in my previous observations and truck actually feels peppier since it stays in lower gears longer on the way up. I have been driving some different routes with it so hard to tell on mileage but I think it is down a tenth or two.
So far I cannot really complain on the tune compared to the previous stock condition of the truck. I really cannot figure out why individual outcomes seem so different, even for those that do not have a GDE tune.
Never overlook the obvious = The Human Factor
Agreed. My first couple days were "wierd". After cold start in the morning (in the 40s and 50s), I would give it 1 - 2 minutes to roll flow and then drop it into drive. I'm easy on the throttle until an engine is warmed up so I'd go down the alleyway to our road easy. Then when pulling out onto the road, I'd give it some throttle. It would started to raise the RPMs for about 1/2 second, then stumble like it was going to stall which lasted for about 1-2 seconds, then it would rev up. The amount of throttle input didn't seem to matter much. After about 4 days of this it just went away and now the throttle input is more "normal". It is warmer out so like you I'll have to assess again when the cold weather returns.
The shift points do appear changed especially on the high end.
You left out the part where you then step out if the truck and face north, jump twice using only your left foot, then, twirl around twice counter clockwise and you should then be good to go.
Discussion Starter #19
I covered some familiar routes for the first time yesterday since the update. It was a route with several short but steep hills withing town limits where the speed limit was low. A couple of these hills were after making a left hand turn from a stop light. Originally the truck would shift up and pretty much roll freely down the hill and significant brake application was necessary. Now it seems to hold second gear and hold back well going down the hill.
After a bit of experimenting it doesn't seem to want to upshift at slower speeds when the accelerator position is at idle and it is clear you do not want to accelerate.
1 - 19 of 19 Posts
