1 - 4 of 4 Posts
View attachment RAM U07 safety Recall.pdf
As stated in the U07 recall this will / may impact the PCM and TCM. The only reason I may get this recall done is to ensure it will not impact resale / trade in value. I am fortune in that I have TWO ECM's one AEM and one GDE that I have and can swap for warranty work. After the AEM update I had to re flash that TCM. I want to know the best way forward and recommendations by GDE to address this issue.
no guarantee GDE themselves will reply to your post .
call them direct : .....1- (248) 977-9531
if you don't want to pay long distance , ask them in a email ,
they always answered all my questions : [email protected]
let us know what they said ,
and BTW , welcome to the Forum BAMA_Boy.
P.S. in your PDF file we can still see your name Bobby .......
BAMA_Boy , you say you have TWO ECM's one AEM and one GDE ,
so that means you had the AEM done , it was discussed that the U07 safety recall is now inside the AEM ,
it is no longer a separate recall update , depending on the date when you got the AEM done you may already
have that U07 in your truck .
try opening your door with seat belt OFF , if you cannot move the truck in reverse or drive ,
because it switched itself to Park , then you have the U07 in your software .
then try again with the seatbelt clicked in behind you , open door and move truck with door open ,
the seat belt clip is the run-around to that safety feature .
Now if you put the GDE ecm in , I am not sure if GDE did not remove that .....
may only be restricted when you have the AEM ecm installed .
again , to be asked to GDE.
EDIT : from post # 19 in here , the auto park mod remains even with GDE tune
https://www.ram1500diesel.com/forum/ram-1500-diesel-general-discussion/65914-gde-tune-120k-miles-questions.html#post992454
so you could test the "door open Auto Park " presence , with any of your 2 ECM.
1 - 4 of 4 Posts
