1 - 5 of 5 Posts
My interior light turns on over bumps but the evic doesn't say a door is open when it happens
the light only turns on for a second and i get one audible chime
Anyone having this issue
2016 tradesmen extended
Most likely the door switch is out of adjustment or defective. Take it to the dealer and have them check it out for you. If you can make a small video of this happening, it will help the service department see what is going on. Good luck.
i was thinking that but the but switch must be inside the latch of the door because i cant see one
Sounds more than switch or wire connection since you heard an audible chime. Hope the dealer would be able to locate it.
1 - 5 of 5 Posts
