1 - 20 of 26 Posts
2016 with 255,000kms.
Drove to work this morning without issue. Came out to head home and got warning on instrument cluster as soon as I drove away.. "Immediate Air Suspension Service/ Repair required"
I went from the best riding truck to the worst while it sat in the parking lot. I'm not on the bump stops but its got to be close. The truck seems to be level on all four corners but does look an inch or two lower than normal. The ride is very bouncy and then hitting the bump stops on large bumps.
Where should I start?
I do have AlfaOBD. Any help would be appreciated.
Font Gauge Speedometer Vehicle Auto part
Yes. It was -7C here this morning. No doubt part of the issue.
Hi: Ecosparky... Well wouldn't that just let the wind out of your sails!!!
Check the fuse for the compressor
Yes. I'm going to sneak the truck into the heated U/G parking lot at the condo near work and let it thaw out today then start troubleshooting.
Dang. I thought it was cold this morning at 65.
Hey buddy didn't realize you are that close to the Arctic Circle.....geez. Have a big ol' steaming pot of coffee on standby, no doubt this is weather related hope it's just an uncooperative fuse.
Reactions: Ecosparky
I remember your post few months ago when it acted up the first time. I would check for leaks first and have alfa obd on hand to aid.
Discussion Starter · #12 ·
what... working on a truck in freezing temps doesn't entice you? come on, where is your sense of adventure.
Been there many times......but I try to avoid it if possible. My old mans body is starting to reject that kind of work. It lets me know every time.
Discussion Starter · #13 ·
So I thawed the truck in the U/G. Pulled the F5 40amp fuse and tested it. At least fuses are getting blown around here.
I think I dodged a bullet. System is working normal........for now.
We should all carry a couple spare 40A fuse (if you have Air Suspension).
Discussion Starter · #14 ·
This isn't that cold yet. Just want to go to bed tonight and wake up on May 1st.
I had that same message appear on my old 2016 Rebel. Believe it or not It was the battery causing it. I replaced the battery and voila the message went away and never came back.
Are you willing to swap weather with Vancouver for this winter?
Discussion Starter · #17 ·
Too much rain in Vancouver recently but the temps are better than here. I'd swap.
Discussion Starter · #18 ·
Now that the Air suspension is somewhat sorted out, the evic reads Service Front Park Assist System.....WTF
Looks like I'll have to replace the sensors for the knock off Amazon set I have on the shelf.
Glad you got resolution on the Air suspension. One thought does come to mind because these trucks are so electrically power dependent is that some of the electronics can be erratic when there is a slight drop in voltage, I know personally I tried to push battery replacement a bit too long (6 years on oem battery) started getting random radio, throttle evic, park sensors. I replaced truck battery and voila everything back to normal, it's just the nature of these power dependent systems.
If it's like any compressor pump that's driven electrically then cold weather will cause a larger current draw that will pop a fuse or trip a breaker. My compressor in the garage will pop the overload breaker on the side of the pump when the garage gets cold in the winter. If breaker or fuse pops in warm weather then the pump is going out!! Keep your fuses handy!!
1 - 20 of 26 Posts
