1 - 3 of 3 Posts
My driver side parking light is dumber than my passenger side and I was wondering what the cause could be and how I could fix it. Any advice would be appreciated. Just bought the truck a month or 2 ago.
Dimness can often be caused by a bad ground, the only thing I can suggest is making sure the connectors are well seated and not corroded. Another way to check is undo the connector and apply 12 volt to the appropriate pins and see if they have the same brightness as the other side. If you have a voltmeter then you can also check voltage at the source pins.
1 - 3 of 3 Posts
