1 - 3 of 3 Posts
Hey just posting a tip for you guys on leveling the air ride suspension. Remove the top link on your level sensor, unplug sensor, unbolt the 2 10mm bolts that hold on the sensor to frame. Take a cut off wheel and cut bracket, weld it back together 1/4 inch higher as shown in the pic and reinstall.you can now slide the sensor up and down for where you want the height to be. For me 1/4” lower was perfect. I realize you need a wire welder and cut off wheel but you can probably just use a dremel tool if needed. Here is the pic for before and after.
86790
86791
I just adjust it with my phone and the AlfaOBD app. No cutting/welding required.
1 - 3 of 3 Posts
