1 - 6 of 6 Posts
Anyone know how to adjust the headlights?
Discussion Starter · #4 ·
So I found the right/left adjust you have to pull the whole fixture out and it's at the back with hex key it's all nicely labelled for you to. The up and down (horizontal) I can't find, it may be the bottom 10mm screw, it seems to have some sort or adjustment there....
If you open the hood and look on the fenders above the headlights you'll notice 2x holes with arrows pointing towards them... Stick a T25? torx driven in and spin for up/down in one and L/R in the other.
Discussion Starter · #6 ·
Awesome thanks!
What's the adjustment screw for on the bottom 10mm one the light? It seems to work in tandem with the screw itself for up down adjustment.... maybe just to line up the housing?
1 - 6 of 6 Posts
