1 - 4 of 4 Posts
· Registered
Hey everyone. I know this topic in general is fairly well discussed, so I wanted to ask some questions that hopefully are a bit more focused than "what should I get?". Here's the 3 things I'm looking to do:
  • I just replaced the license plate and reverse light bulbs with some Sylvania Zevo LEDs. I love the look and brightness, but I get the infamous "bulb out" messages. Are there any LEDs on the market that do not require getting a resistor pack?
  • If I do have to get a resistor pack, are there better ones than the Sylvania ones? Plug-and-play maybe?
  • I upgraded the fog lamps with ZEVO LEDs as well. I love the extra brightness as well the color (6k). I'm looking to upgrade the low and high beams as well (projector lamps). I've seen a lot of debate around which LED bulb to get, as well as some liking the zXe bulbs. I'd prefer the LEDs myself so I'm not having to constantly replace the bulbs. Are there any that do not trigger the "bulb out" message? I've seen good reviews around the GTR(?) LEDs, HR LEDs and the Hikari LEDs. Any one better than the other?
Thanks as always!!
· Registered
The best way to get rid of the bulb out message is to use AlfaOBD. You can change the setting on the lights to accept the LED bulbs. Do some searching on it and you will be surprised what can be done. You also might ask to see if there is someone close that can change the settings. The dealer can do that too.
· Registered
I didn't have to change any settings with AlfaOBD when I put LED's in my projectors. Just look for CanBus compatible bulbs. I like the 6k color in all my bulbs as well.
There are CanBus compatible LED's for the license plate bulbs as well. I run them in my truck and in my camper's marker lights.
· Administrator
What's weird is I used the same Zevo LEDs for my license plate lights and I don't get a bulb out warning. That's even more impressive as mine is a '15, they're notorious for being picky about the bulb out detection.
Read up on LEDs for projectors, some work better than others. I don't think I've read about anyone using Zevos. Another thing about LEDs in projectors is how you have the "bulb" indexed in the housing can change the light pattern.
1 - 4 of 4 Posts
