1 - 14 of 14 Posts
Hey gang,
Magnaflow has now introduced their 2.5" Performance Series Dual Cat-Back Exhaust System
Material: 100% Stainless Steel
Tubing O.D. Size: 2.5in.
System Type: Cat-Back
TIP O.D. Size: 5.0in.
TIP Quantity: 2
Single/Dual: Dual
Exit Position: DUAL SPLIT REAR BEHIND REAR TIRES
Features and Benefits: Lifetime Warranty, Dyno Tested And Proven To Make Power, Performance Gains In Horsepower And Torque, Great Sound -Has A Smooth; Deep Tone, Easy To Install, Mandrel-Bent. All Welded. Built To Last.
Rollin Smoke Diesel. 2014 Ram 1500 3.0 EcoDiesel Magnaflow 15253 2.5" Performance Series Dual Cat-Back Exhaust System
James
RSD
Hey James have you gotten any performance parts installed in your ed this past weekend ?
Hey friend, Installed the Bluespark module, debadged the emblems, bedliner tomorrow and window tint on Wednesday.
Edge CTS will be here this weekend, very limited PID's for now and will be installing that on the pillar with the Edge mount.
Waiting for my AFE cold air intake and the cat back exhaust.
James
RSD
@RSD - sure hope you have been taking lots of pictures and videos cuz you are about to be flooded with a lot of questions lol ... can't wait to see the Edge gauges and some of your write up/reviews.
Hey gang,
TIP Quantity: 2
Single/Dual: Dual
James
RSD
Do they make a single exhaust pipe version? The ED Outdoorsman trim has a single exhaust pipe on the right side.
Discussion Starter #10
Can u always keep the CtS no matter what tuner u run? How does it hook up?
Yes, as long as the tuner is not a unit that requires it to stay plugged into the OBD port (example HS Mini Maxx on the light duty diesels)
On my Powerstroke I run the Edge CTS with a SCT programmer.
The Edge Insight simply plugs into the OBD port and reads the parameters through there. Only thing is a pyro probe will need to be drilled and tapped for the EGT's.
James
RSD
1 - 14 of 14 Posts
