21 - 37 of 37 Posts
What if you are out in the woods, away from cell towers, and you need to know altitude (medical reasons, yup).
Old-style altimeters used barometric pressure and are rarely used these days. Phones and GPS units use GPS satellite data, so are not dependent on cell service. My phone altimeter seems to be precise within +/- 30 feet, so should be fine for medical questions.
89469
89470
I believe this is the screen you folks are looking for ? I was board while the girlfriend was taking pictures on Vacation.. I Decided to play with the radio and check elevation vs posted signs, It was reading about 50-100ft difference and the altitude would vary ...
It should be remembered that the elevation signs on side of highway are not exact. Their close but between surveyor setting stakes, and sign techs installing signs they move. Same with mileposts, if your going to use them to check speedometer need to do over 10 miles so errors average out.
Reactions: SlowRoller
I have used mileposts to check the odometer, and I like to go 50-100 miles to get reasonable precision. I assume that the speedometer will be correct if the odometer is. However, I notice that when there is an electronic sign telling me my speed, it usually indicates about one MPH less than the speedometer (both in the ED and my Honda), so maybe the speedometer does read a smidge high. I may try a check over a flat stretch in AZ or NV in the next week, but it's hard to keep a perfectly constant speed while towing.
I see people here saying they check distance by GPS. Is that the built-in navigation system, or can that be done with a phone or handheld GPS unit?
Any GPS will do. They all lock onto the same satellites so theoretically all GPS devices will read exactly the same. However, they all will not lock on to the same number of satellites or in the same order. Thus, their readouts may differ but the difference is very slight. For practical purposes, they will all give the same info.
I don't know how to get it to measure distance traveled on the phone. I don't think the map apps will do that, so I was wondering if there is a separate app. I use mileposts to check the odometer, but that isn't always convenient.
I don't use my phone for Map data so I cannot help you. I use my Garmin Nuvi. I also use a phone app called Speedometer that is GPS based. Try it, it's a simple speed and distance display.
Discussion Starter · #29 ·
I’m still laughing over systems that provide “Altitude” vs the correct term “Elevation”. For those who didn’t read my previous rant...
Altitude is the height above ground indicated in MSL (mean sea level) or AGL (Above Ground Level). Elevation is the height OF THE GROUND above sea level. For instance, if you are in Denver (the mile high city) and standing in front of the State Capitol building (actually on the 13th step) you are at 0 (zero) altitude but 5,280 feet MSL elevation. If you climbed up the flag pole (assuming its 100 feet tall) you’d be at 100 feet AGL (Altitude measurement) but 5,380 feet MSL (Altitude measurement). There would be no measurement of elevation up at the top the flagpole.
^^^^^ Semantics
Discussion Starter · #31 ·
That’s what I get for being married to a Literacy Specialist. LOL
I trust Merriam-Webster: " ALTITUDE is preferable when referring to vertical distance above the surface of the earth or above sea level; ELEVATION is used especially in reference to vertical height on land. "
Discussion Starter · #33 ·
I agree, but to clarify, the reference to vertical distance above sea level means in the air, not on the ground.
Discussion Starter · #35 ·
For a “SlowRoller” you sure seem to enjoy a debate. Lol. If that works for you I’m happy.
I could not choke down the cost of activating the Nav on my truck when i bought it...not after having owned 3 gps units prior. All of which the cost of all three did not even come close to the activation fee of the stealership. I found the Garmin LM-770 refurb and snagged it up. It will display a bunch of stuff. Including Altitude and Grade %. i'm still learning the nueances of it, but like the fact i can plug the Camper data in and have it find roads that dont have low overpass/bridge undercrossings that i could get stuck under. There's my .02. Happy Hunting! :)
21 - 37 of 37 Posts
